Question about Roper Washing Machines
Have a washer model # RTW4305ZQ0 Agitator makes noise when in in agitate mode
  • 1 more comment
  • Dick Smithberg Dec 06, 2012
    Good Morning, On My roper washing machine model RTW4305XQ0 I've checked the dogs and they look good. Also looked at the direst drive motor coupling and they look fine. What else could make my washer make noise in the agitate cycle?
  • Richard Roth
    Richard Roth Dec 06, 2012
    You will need to look at the drive block. Take a look at this video.
  • Richard Roth
    Here is the drive block if you should find it bad.http://bit.ly/YSv4ma
    Top Expert:
  • Roper Master
  • 9,472 Answers
Does it also make noise in the spin cycle?
Posted on Dec 05, 2012
  • 3 more comments
    Hi Richard,
    Let me be a little more descriptive. When it agitates it makes any annoying noise. Performs normally in the rest of the cycles. I checked the "dogs" and they look OK. What is your solution to eliminate the noise? Thanks, Dick
    "any" should be "an"
  • Richard Roth
    I was thinking the motor coupler was going out. Here is that part.http://bit.ly/Vd0CSQ
    only makes noise in the agitate cycle
SOURCE: Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Posted on Sep 09, 2008
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
csmock132
  • 4669 Answers
SOURCE: Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Posted on Feb 28, 2009
  • 240 Answers
SOURCE: INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Posted on Apr 28, 2009
  • 30 Answers
SOURCE: Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Posted on Jun 02, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Noise in washer need to know how to remove agitator
For most Kenmore, Whirlpool, Estes, Maytag, and some GE washers the top portion of the agitator can be pried off (either a cap or fabric sofrtner dispenser depaneing on make and model) and there is a bolt underneath. Once removed, the agitator can be lifted straight out. Some GE's you have to actually "pop" the agitator by placing a strap underneath and lifting it out that way. If your are still having trouble, reply back with your model and serial number and we can go from there.
Jun 18, 2008 | Washing Machines
Kenmore washer making noises while adjitating
could be worn agitator dogs try turning upper portion of agitator by hand and listen for slight rattle or motion in both directions if dogs are bad remove cap and center bolt pull upper part of agitator off dogs are in ceter of upper part ..part number 80040
Jun 09, 2008 | Kenmore Washing Machines
Agitator clicks in wash mode sometimes, stops agitation motion then returns to normal wash and click noise stops. Please comment. Thank you, fred elam
got a model # It may be in the gears of agitator if you have a 2 piece agitator... is the bottom of the agitator moving still when you say it stopped ?? AND Its Just Top of agitator stops?
Sep 02, 2007 | Kenmore 22932 Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
