Question about Technics Audio Players & Recorders
Cd player keeps saysing no disc
I have a sl-ch510, ive tried a lens cleaner and it still says no disc
  • Technics Master
  • 1,258 Answers
There are other reasons that the player may not detect a disc. One of them is the platter height of the spindle motor- they go out of position sometimes as they are pressed on plastic. It may need to be set back to the standard. You can also have a bad spindle motor that can not spin up or has a dead spot on the motor. Many possibilities.
Posted on Dec 11, 2012
  • 133 Answers
SOURCE: MY CD PALYER DOES NOT WORK. ''DISC NOT FINALIZED'' IS DISPLAYED.
If your CD player has been working for many hours and cleaning the lens didn't help, then the next thing to do is changing the spindle motor (the one that spins the disc), since the brushes and the commutator get dirty/oxydized with many hours of performance.
The motor can also be cleaned, but it's kinda complicated and delicate to do it, so you might want to change it instead.
The same holds for the slide motor (the motor that changes the position of the laser pickup).
To clean the motor you need to desolder/remove it and open it up (you need to bend out the clamped parts on the motor housing to release the cover - also, mark the position of the cover so you can put it back in place in the same position as it was prior to opening it - some motors have an indentation so that the cover fits in place in only one position).
Then you need to remove the cover (this is a delicate procedure as you can easily damage the brushes).
You can clean the brushes and the commutator using a long pointed scalpel - gently scrub away the brownish/black residues on both the brushes and the commutator.
Now you need to put the motor back together, taking care not to damage the brushes when you put the cover back in place (kinda tricky but it can be done).
After closing it, see if it runs smoothly, you may want to try and run it on some 3 volts - it must run quite silently, with no more than a gentle humming sound.
If it runs ok, you should use a tiny flat screwdriver and a small hammer to bend the housing edge back onto the cover to fix it in place (basically, you need to rehammer back in the clamps that held the cover in place, this is also a bit tricky and delicate thing to do).
Now reinstall/resolder the motor back in place (motors on some brands/models can be worked without removing them).
Well, i've just told you how i repaired quite some CD drives which were virtually dead, i'm actually still using a yamaha which is more than 15 years old (i myself have been using it for at least 10 years now), i got it as a scrap piece, it returned to life after the above described procedure and it actually works perfectly up to date.
Anyway, i guess the easy way is to simply replace the motors (they need to have the same axis dimensions and mount holes as the original ones, also they need to run on the same voltage - things to keep in mind when you are looking for new motors).
Hope you can get it working...
good luck
3rq8 (Triarcuate)
Posted on Jul 24, 2009
HOEEEE
  • 7 Answers
SOURCE: Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
Posted on Jan 05, 2008
SOURCE: malfunctioning cd player
Did you try taking out that lttle circle thing that you put your cd into.Well,take that out and then clean it.Then,insert it back and it should play your cd
Posted on Dec 15, 2007
petraman7
  • 1175 Answers
SOURCE: cd player skipping
The DVD transport rides on chrome rails. These get dust and stuff on them and wont allow the optics to track.
If you dare, open the unit UNPLUGGED from the AC.
See if you can get at those rails easily. clean with WD40 on a swab. clean with a new swab . then a couple drops of mystery oil on a swab and run down the rails over and under.
You must be VERY gentle if you clean the lens with isopropyl
Posted on Feb 24, 2008
jomabug76
  • 1148 Answers
SOURCE: Technics SL-PG440 CD player no audio output
GET NEW RCA JACKS
Posted on May 15, 2009
We cannot use this because the CD's all skip. We found out that there aren't replacements to buy, we tried at Best Buy. we really miss being able to play CD's. Can you help.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Take care.
Feb 03, 2011 | Technics SL-PD687 5-Disc CD Changer
States no disc when disc is in unit and will not play
Welcome to Fixya
Lens might be dirty that is why it is giving the unit hard time to read the disc. Try to use a cd cleaner first to clean the lens.
Thank you for using Fixya!
Jan 18, 2011 | Panasonic SL-S292 Personal CD Player
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
CD's come out distorted on the TECHNICS SL PG 580A
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Feb 26, 2009 | Technics SL-PG480A CD Player
Lg rh177
Could be the dvd player/lens. The player sucks up dust through the
player's caddy and after a while it won't read discs anymore.
A cd cleaner or a good (gently dosed) blow with compressed air might help.
Oct 17, 2007 | LG RH177 DVD Recorder/HDD Recorder
Fw316C cd player will not read discs
Buy A CD Lens Cleaner and put it in to the CD Player and keep retrying until the drive plays it and then follow the instructions for the CD Lens Cleaner after its finished try playing a CD if it still wont play try another disc and if it does not play that try reset the player by unplugging it for five seconds if it still wont play the CD drive has failed in the drive and you need a new stereo. Stereos dont last forever so dont be surprised if you need to buy a new one
Aug 17, 2007 | Philips FW316C37 Shelf System
536 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
