Question about Marantz Audio Players & Recorders
MARANTZ SR 5500 will not turn on
Hi guys, i am hoping you are able to help me with my problem. my amp has been working fine without a problem since i have had it, i use it every day, but this morning when i went to use it, it would not turn on, but the power light on the unit was flashing. would you have any idea's at all??
    New Friend:
  • 111 Answers
The protection circuit is your amp is turned on by itself or its protecting your speakers from burnt output transistor stage of amplifire circuit.sometimes it happense because of bad solder joints of the printed circuit board.if you are technicaly sound please resolder all the joint of pcb power and putput sections.if you need more help please comeback.
try to do it by yourself.
nuwan..
Posted on Jan 12, 2009
My Marantz SR-5000 will not power up. All connections seem to be fine. Does this receiver have a fuse?
Doug
Did you ever get this problem resolved? I have a chance to buy one of these from a guy who indicates he's having the same problem, but if fixing is going to be a bit expense, I will pass.
Oct 09, 2010 | Marantz SR-5000
What would work better for Marantz SR 4200 Apple Composite or component cable? In order to play music through the amp as well as watching videos
Component Video is a big step up the food chain in quality. Component Video inputs are for video only, not for audio. I don't see Component Video inputs on the Marantz SR-4200; only Composite and S-Video. S-video would be a step up from Composite and it carries analog stereo sound.
You don't give any clues as to the source's audio capabilities.
Digital Audio of either flavor is preferable. Grab the best possible TV-related audio from your Cable/Satellite box to the Marantz and run a pair of RCA audio cables to your TV just in case you want to watch the weather channel without hi-fi sound.
Mar 18, 2010 | Marantz SR-4200 Receiver
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Jan 19, 2010 | Marantz SR-18EX Receiver
Hi Guys, Have marantz sr 7000 in for repai and
what is the location number of (c104) part.
Nov 22, 2009 | Marantz SR-7000 Receiver
Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
May 31, 2009 | Marantz SR-19 Receiver
Replacement power cable
Dose not matter use one with 3 holes as you put it,it will work ok.
CABLE GUY.
Apr 18, 2009 | Marantz SR-4400 Receiver
Marantz model 5500 AV Surround Receiver
Hi, hope this helps, try (1-800-remotes), these guys have a wide selection.
Oct 22, 2008 | Marantz SR5500 Receiver
No audio
Go to amp set up menu and make sure it knows the cables you are useing,ie-if the dvd is wired with coax for sound go to input set up and tell the amp you are useing this type of cable.If this is not the problem and the sound is going off one device at a time your amp needs to go back to your dealer.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Marantz SR-5600 Receiver
Martantz SR 3000 - Are there any remote codes
Hi, sorry it took so long for me to get back to you. The system does not give us updates on older problems.
Found the manual, and it does have 5 digit codes, Page 2 lists the codes for marantz as 0321, 0269. Hope that helps you.
regards
robotek
May 30, 2008 | Marantz SR-3000
218 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
