Question about Proform XP Weight Loss 620 Treadmill
Treadmill will not elevate, has not since new but we procrastinated so now out of warranty
    Top Expert:
  • Proform Master
  • 12,223 Answers
Please RUN the software calibration for easy diagnose, troubleshooting and fix it.
Otherwise you must see the diagram attached and proceed according.Lube the motor and tigh any plug for the elevation motor
God bless you
treadmill will not elevate, has not since new but  - 12_5_2012_9_24_16_pm.jpg12_5_2012_9_25_05_pm.jpg
Posted on Dec 05, 2012
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
2)Alternative:
Jun 19, 2013 | Exercise & Fitness
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
I have a Horizon QuantumCS 11 HRC Pacer Treadmill and I am getting E7 flashing when turned on,belt moves for seconds and then stops
please follow the steps and fix it. God bless you
2)Alternative:
Nov 15, 2012 | Exercise & Fitness
I plugged it in and it will not start. It was working fine yesterday but now nothing.
Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your treadmill to find the elevation motor. The treadmill fuses are located inside the elevation motor. If you don't have the manual, contact the manufacturer of the treadmill and ask if it can send you one or if there is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its side and use a screwdriver to unscrew the lid off the elevation motor. Carefully remove the fuses. Some treadmills have easy access to internal parts where you don't need a screwdriver. If this is the case, simply lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
Sep 06, 2011 | Sears Exercise & Fitness
Elevation is elevating in the wrong direction
Unless this unit was physically re-engineered,either the rear end incline on some models or from the front depending on the mechanism look closely when you fold it up chances are you will be able see that mechanism thru the bottom cover slot made bigger for the rear wheels to move.
Apr 09, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Proform XP Weight Loss 620 Treadmill Logo
49 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
