Question about Dell Office Equipment & Supplies
Win 7 "cannot identify device" Dell 1600n
On Windows 7 machine, downloaded and installed Dell drivers for Dell 1600n network printer/scanner MFP. On setup, printer is not shown in list of printers. Click on "add printer," and driver automatically identifies the correct IP address for the printer (and shows "port name" "IP_[IP address"). Click "next" and says repeatedly "cannot identify 192.168.1.4 device [ IP address of printer ]." How do I resolve this?
SOURCE: Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Posted on Aug 29, 2008
SOURCE: Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Posted on Feb 28, 2010
Geekman
  • 32281 Answers
SOURCE: The IP address of my
Delete the port with the IP address 192.168.0.4 for that printer and then Add Port
Posted on Sep 18, 2010
  • 3278 Answers
SOURCE: The port to which the
Hello.
Just some thoughts:
1. Configure your printer as a TCP/IP network port, on your Windows 7 laptop
2. Disable your laptop's firewall and antivirus software to see if there is interference
3. To see if the message is not coming from the printer at all - try disconnecting the printer from your router and see if you still get it
Hope this helps.
Posted on Jan 25, 2011
muntejaya
  • 10421 Answers
SOURCE: Trying to install HP LaserJet M1522nf MFP printer
Please get it downloaded here : www.siliconguide.com > Drivers > Printer > HP
www.opendrivers.com/.../hp-free-driver-download.html
www.brothersoft.com/downloads/hp-printer-driver.html
Jay lpag
Posted on Feb 13, 2011
All functions work on my 1600n printer with the exception of the scanner. The workstation names that normally appear when a doc is scanned do not appear
The Dell 1600n requires that the Dell Network Scan Manager is running. Windows Vista and Windows 7 require user level authorization for this app to run properly and may be prompting you at start up. If you are telling it "no" when propmted then this is one thing that can be hanging you up. It is also possible the app is simply not running at all. Go to start>programs>Dell>Network Scan and see if it picks it up then. This app is how the dell printer itself gets the names to put in the list of available workstations to scan to.
Jul 26, 2011 | Dell 1600n All-In-One Laser Printer
Driver dell lazer mfp 1600n
You can download the Driver for the Printer from the link below. Please select the Operating System installed in the Computer and then download the Driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_LSR_1600N&os=WW1&osl=en&catid=&impid=
Jul 02, 2010 | Office Equipment & Supplies
Ine windows 7 fo dp3030
http://www.panasonic.net/pcc/support/mfp/dp-3030/pdl/download.html. then go down on PDL Printer Driver without installer (Beta) and download driver. extract it win some d or e drve and manaually install network printer and Enjoy!!!!!!!
Feb 25, 2010 | Panasonic Workio DP-3030 Printer
Where can i find free installation software for a
for your free installation go to :
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen&~ck=mn thanks AJ
Nov 15, 2009 | Dell 1600n All-In-One Laser Printer
DELL 1600n drivers for 2003 Server (Network Scan)
  1. Click the file name below to download the driver:
    R165289.EXE
    new_note.jpg Note: By downloading, you accept the terms of the Dell Software License Agreement.
  1. Click the Save button.
  2. On the Save As: window, verify that the R165289.EXE file name is listed in the File name: box, and then click the Save button.
  3. On the File saved window, click the OK button.
Back to Top
» Install the Drivers, Files, or Utilities
  1. Locate the file. It is usually on the Desktop or in the My Documents folder.
  2. Double-click the file icon and click Continue.
  3. In the Select the folder where you want to unzip the files to window, click OK.
  4. If a message appears asking to overwrite the folder, click Yes to All. If a message appears asking to create a folder, click Yes.
  5. In the All files were successfully unzipped window, click OK.
  6. Follow the prompts that appear to install the driver.
  7. If prompted to restart your system, click OK.
Nov 26, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Oct 30, 2008 | Dell 1600n All-In-One Laser Printer
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Feb 22, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Windows Vista can't find networkd Dell 1600n
Make sure you're using the drivers for Vista, which can be found on support.dell.com. You'll want to use the choice for Vista 32-bit.
Also, try turning off your firewall, as it may be blocking the network data.
Dec 15, 2007 | Dell 1600n All-In-One Laser Printer
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
