Question about Kobo Computers & Internet
Dropped Kobo Mini. Top left corner of case partially opened. How do I close it again? Top and left side of case are half-open. Top right and bottom left are still fastened shut. (it is still under warranty)
  • mybluegita
    mybluegita Dec 06, 2012
    Don't know how or why my question now has the heading 'Kobo monitor' attached, but it's misled some of you. This is NOT a monitor. This is a small, hand-held e-reader.
    Top Expert:
  • 14,553 Answers
Most of these snap together and if snaps cracked.......
Posted on Dec 05, 2012
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Remove cover
Its a snap together job But unless you know where to start something will snap. Try the Samsung Tech support for this product. Even if the Back light or inverter or some other do able thing is doable- getting parts may not be so easy for you. So follow their advice for service.
Posted on May 15, 2007
chinna_1977
  • 65 Answers
SOURCE: How do I open the case of a Philips 107S 17" CRT Monitor?
Recently most of monitors Like samsung and LG appears 2 screws at the bottom and Internal fixing at top .push it to appear some Gap of top side
Posted on Oct 06, 2008
tbreeze47
  • 3083 Answers
SOURCE: Samsung Syncmaster 740NW vertical blue stripe
I've never opened one of these units, but I think you're right...a broken, cracked, or "cold solder joint"...had that problem on boards a lot of times. What has been assembled, should have a way of disassembling, unless the plastic was molded or glued after assembly, which is almost never the case, to my knowledge. Sometimes screws are hidden under labels, paper or metal plates, anywhere, really. If you can drop by a computer repair shop, you might be able to pick their brains about where the screws are, just depends on the person working there. Only other choice is to get the repair manual, but they're expensive and hard to locate, sometimes. Anyway, keep working on it, I think you'll figure it out!
Posted on Mar 14, 2010
  • 1684 Answers
SOURCE: my elo toch screen does not work right. when i
The calibration is off. Go to start and then control panel. In control panel you should find an icon for ELO calibration. Click this and start the procedure. The calibration will ask for you to touch several places on the screen in little circles with bulls eyes. After this the screen should be corrrect.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Mar 18, 2010
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
Make google my home page
IN order to make google.com your home page with windows (I will assume XP)
open internet explorer or firefox , or google chrome,click on tools
internet options and then in the address bar section HOME PAGE enter www.google.com apple and ok. hit the red X to exit your browser.... then open it again and it should give you google.com
let us know if it worked out well..
check out www.LegalMobileSecurity.com1
Jan 06, 2014 | Microsoft Windows XP Home Edition
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
How to change air filter 2003 mini
After opening the hood, locate the air filter box, which is just to the rear right corner of the engine. It is connected to the engine via a thick plastic tube.
Remove the tube clamp that joins the plastic tube to the air filter box. The tube clamp is a metal ring with a simple clasp on it. To release the clasp, slide the tip of a flat-head screwdriver in the opening and twist it to either side. The clamp will loosen, allowing you to pull away the tube from the air filter box about an inch or so.
Remove the two metal screws on the right side of the air filter box. They're located along the seam where the lid meets the bottom of the box.
Slide the lid to the left about a half inch; it won't go much farther than that. When it's as far to the left as possible, lift it off.
Pull the old filter out of the box. Give it a close look if you'd like, and if it doesn't appear particularly dirty, put it back in. Otherwise, discard it.
Put in the new, clean filter in the old one's place.
Put the lid back down so it's just to the left side of the bottom of the air filter box, then slide it to the right until it snaps into place.
Replace both screws on the right side.
Slide the plastic tube back onto the air filter box and squeeze the sides of the tube clamp together to lock it on.
Sep 23, 2010 | 2003 Mini Cooper
Cant log on to facebook
Open Internet Explorer and click tools on the top.
Fo to Internet Options
It'll open up a window, click on advance on the top right corner and then click Reset (at the bottom).
It would prompt you to reset again, click it again.
Click Close when its done.
Close all Internet Explorers you have open and open it again.
And now try it again.
Mar 31, 2010 | Facebook Social Network
S7310n disassemble
This is HP Support, and the download page for the Upgrading and Servicing Guide,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1156509&
On this page scroll down to - Upgrading and Serving Guide, and left-click on it.
(Second file listed)
This is a PDF file download. The computer you are using has Adobe Reader on it, which uses PDF files.
After you click on the Upgrading and Servicing Guide, file name, you will Not see anything happening for up to 30 seconds, or so.
Be patient, as the file is downloading in the background.
The Upgrading and Servicing Guide tells you, and shows you, how to open the computer case. (Page 7)
Barring that you are not able to download this PDF file, I will attempt to tell you how to open the computer case. (If you are using a Dial Up network connection, you may be as old as me, before the file downloads)
1) Computer off unplug the power cable FROM the surge protector. (Not shouting)
THEN unplug the power cable from the back of the computer. (Power Supply)
Now unplug all cables connected to the computer.
2) Lay the computer on a towel on top of a table. Keeps the table, and the computer from being scratched.
Lay the computer on it's Right side. (Computer facing you, the right side is to the right. Hey, don't laugh, lol!)
Loosen and remove the three computer cover screws, on the back of the computer's case.
The computer cover that removes is an L shape. It comes down the Left side from the top, and wraps under the bottom.
Looking at the Top/Back of the computer, there is a screw to remove on the Top, of the Left side of the computer case. (Top/Left side corner)
Looking at the Bottom/Back of the computer, there is a screw to remove from the Bottom, of the Left side.
(Bottom/Left side corner)
Looking at the Bottom/Back of the computer, there is a screw to remove from the Bottom, of the Right side.
(Bottom/Right side corner)
After these three screws are removed, the Left side of the computer cover is slid back about 1/2 inch, (1.25cm), and lifted straight up.
BEFORE you reach inside! (Not shouting)
Your body carries STATIC electricity.
Static can fry out, (Short Circuit), the hardware components inside the computer.
TOUCH the metal frame of the open computer case, to relieve your body of Static electricity.
If you get up, walk away, then return, Touch the metal frame again.
Now, do you wish to disassemble this desktop computer completely, or just remove, and replace a few hardware components?
The above Upgrading and Serving Guide from HP Support tells you, and shows you,
1) How to remove, and replace the computer cover
2) How to remove, and replace Ram Memory
3) How to remove, and replace an optical drive.
(CD/DVD Drive)
4) How to remove, and replace a PCI card, that is in a white PCI expansion slot, on the motherboard.
5) How to remove, and replace the CMOS battery
6) How to remove, and replace a Harddrive
Should you need further disassembly guidance, let me know in a comment.
Feb 01, 2010 | HP Pavilion s7310n (EN996AA) PC Desktop
Filmy appearance and spots on the underneath of glass
Today I opened my V200 without much problems. First unscrew the two screws under the lid. Then turn the V200 upside down. Lift the base plate up, gently, beginning at the back (a little twisting is needed). Take care not to force anything. It took me 10 minutes. Fold everything open like a suitcase, then clean the glass inside...
To close again start with the front (sort of click system)
Jan 17, 2009 | Epson Perfection V200 Flatbed Scanner
Mini Roof
yes i had the same problem with our mini Up until i found that in the boot there are two lever one on either side. The left side,has two little switches to allow the sunroof to open and close,so if the lever does NOT touch the switch the roof wont fully work or will open half of your roof and the red light will stiil flash.. as soon as you touch those buttons on the left side of the boot it will open.........RIGHT BEHIND THE LEVER NOT EASY TO SEE GOOD LUCK....
Dec 15, 2008 | 2005 Mini Cooper
Computers & Internet Logo
126 people viewed this question
Top Kobo Computers & Internet Experts
 Mikey
Mikey
Brett Duxbury
Brett Duxbury
Martin Benjamin
Martin Benjamin
Are you a Kobo Computer and Internet Expert? Answer questions, earn points and help others
