Question about Euro-Pro 9120 Computerized Sewing Machine
I can't find any customer service information on the Euro-Pro 9120
I've taken the machine as far apart as I can with the manual and there doesn't seem to be anything stuck in it. It won't run forward, It goes half a stitch and stops, while emitting a loud buzzing noise. The noise stops if I turn the machine off and on, but it doesn't sew and the noise comes back. I have removed the thread, needle, throad-plate, bobbin, bobbin case and race and still the same problem - even when turned by hand. I can turn it backward with no problem or sound effects. I've run out of options and need pro help.
  • Euro-Pro Master
  • 7,365 Answers
Try this link and on the left hand side of the top look for live chat
and see if they can help you.
http://www.euro-pro.com/europro/default.aspx
or try this link and see if you can get any help there
http://www.sharkclean.com/cgi-bin/livew/site.w?location=mcopy.w&mcopy=customerSupport&target=main&frames=no&sponsor=000006
Posted on Dec 05, 2012
RickE1
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
bargainbox
  • 1388 Answers
SOURCE: Euro-Pro 7133 - Thread is getting stuck underneath
Make sure you clean up all the oil......it is not a universal cure all contrary to opinion....
Now, down to business..........
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 25, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
  • 3 Answers
SOURCE: help me find a manual for a euro pro 7133 sewing machine
I hope this helps. It took some searching but this is what i found. Good luck!
http://www.sharkclean.com/manual/7133_REV_1204_ENG-SP-FR.pdf
Posted on Jan 22, 2010
SOURCE: I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
Posted on Mar 19, 2010
EuroPro 9120 manual
http://c965842.r42.cf2.rackcdn.com/9120.jpg
I'm not sure the link will work, if it's doesn't, in your browser type in
euro-pro 9120 instruction manual & it will show this one at sewingpartsonline.com
please let me know if the link works or not
or try this link to mastersewusa.com--I think this one is cheaper than the other
one
http://www.mastersewusa.com/images/euro-pro_9120_cover.gif
Jun 05, 2012 | Euro-Pro 9120 Computerized Sewing Machine
Need manual for shark sewing machine and phone
I've done searches thru all of my sources for a free manual many times for 384, but never found one. I've only found one site that offers them for pay. It's at http://www.sewingpartsonline.com/instruction-manual-euro-pro-384.aspx.
I'm afraid I've never found a service number for them, either, but you may well be able to find one in the manual. Best of luck to you. Maybe you could post the service number on the site for others if you finally get it.
Jun 22, 2011 | Euro-Pro Shark 60 - 384
Needle wont go up and down wont stich
Rethread your machine, I think that your thread is caught somewhere, If you need help call Euro Pro customer service
Aug 24, 2010 | Euro-Pro 9120 Computerized Sewing Machine
Looking for a replacement foot controller for a Euro-Pro 9120
You may be able to get it from Euro Pro or a generic/universal model from a sewing machine dealer. They may need to see the machine to determine the type socket needed.
May 11, 2010 | Euro-Pro 9120 Computerized Sewing Machine
Euro-Pro Model 9110 Monogram
are you sure that is the correct model #?
Check out http://www.euro-pro.com they have
has all the information including a downloadable manuals(pdf file)for most of their products
Dec 06, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Electric Cord
i.ve decided to part out my shark call me (john 9042623457) for price on all except computer (suspect bad) have all attach,pedal cord bobbins,etc.
john
Oct 29, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Euro-Pro 9120 Computerized Sewing Machine Logo
69 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
