Question about Lands Phones
I have a Comdial Edge 120. Whenever I pick up an incoming call the phone does not automatically pick up that line. I have to push the Line button to answer that paricular call. How do I change it so that when I pick up the handset the phone will switch to the current or next incoming call?
  • 131 Answers
SOURCE: Phone won't ring
Hi Melissa,
The phone system (cpu, Brains, Switch) is set for auto answer on your Ext. Either power was lost, programming changed or something along those lines. It is global, so if a call "rings" @ your phone, (any call) you can just lift the receiver and speak.
It sounds like the associated phone lines ringing in "lost" memory of your extension. Therefore it must be programmed or in the case of a toshiba system it has a software "glitch or bug". usually due to "I don't know". So I usually find a change was done to ringing by the vendor or just power loss to the system.
there are a million variables because it was manufactured in asia usually. I would need some more info. to be sure. I can tell you it is NOT your phone. try to reset the phone by unplugging for a minute , if no luck you will need the vendor to reset your Ext. with a laptop or do it yourself with the codes from the main or switchboard ext. I am sure I can give you the info to do this and make it ring again, but you are best off calling the dealer in case fat fingers get wild . you could do much harm by trying by one wrong entry and it is what I call Jinglish ( Japanese English or bad translation) in the manual. $80 or so is worth it , mostly if someone was out to change stuff while you where gone.
Or jus unplug the phone system and wait 1 minute before plugging it back in,  that will reset the system kind of like rebooting windows and forcing it to re - load the system.
Good luck, let me know.
Bob
Posted on Oct 19, 2007
SOURCE: receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Posted on Oct 17, 2008
SOURCE: answering call
Feature ** 266344 password 266344 (assuming the default passwords are set)
A. Configuration
2. Line Access
Show set (enter the telephone extension set number that needs to be changed) ex 34
Then press enter 4 times until you see the 'Prime Line'
Press the change button to set the desired line that will activate when the handset is picked up.
(It will probably display 'None' at present before change)
Press enter and release.
Posted on Apr 11, 2009
issikiki
  • 563 Answers
SOURCE: Norstar M7310 phone doesn't ring and doesn't pick up calls
You can look at the manual here:
http://www.fixya.com/support/p98000-norstar_m7310_corded_phone_nt8b21ac03/manual-34096/page-3
Posted on Jan 26, 2010
SOURCE: When I pick up the handset, the intercom picks up.
This programming needs to be done from Ext 10 or 11
Press Feature 00
Press LEFT intercom TWICE
Press RIGHT intercom ONCE
press the 2 digit extension number you want to set up
PRESS ** ( STAR STAR)
then press the lines in the order you want them to be picked up.
When finished:
PRESS ** (STAR, STAR)
PRESS feature 00 to exit programming.
Done
Posted on Oct 11, 2010
Testimonial: "Thank you! I couldn't find this programming anywhere and you made it simple! "
How do you check voicemail on the comdial 7260 edge 120?
There should be a voicemail/Vmail button on the phone. From there, you dial in the extension and password.
Jul 02, 2014 | Comdial 8324S-PT Corded Phone
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
Change the line selected when lifting the handset (from #4 to #2)
that is not a user option it must be programed by a tech. it is a feature called idel line prefrence the other way iy can be accomplished is by using a hunt group but you will still need it to programed by a tech, you can contact me by email @ brcrory@buyrite.com
May 05, 2010 | Comdial Impact 8124S Corded Phone
Making the date and time show after the phone rings.
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Jan 16, 2009 | Comdial 8324S-PT Corded Phone
How do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
Jan 07, 2009 | Comdial Lands Phones
Receiver dosen't pick up line that is ringing
Press feature00
press **
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Comdial dx-80
The LCD display has completely disppeared on my Comdial DX-80 - the main programmable phone for the group. While the other phones in our systme are fine. I can't see anything on the LCD. Anyone know why? How to get it back? Otherwise, the phone seems to work fine.
Feb 21, 2008 | Lands Phones
Lands Phones Logo
173 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
