Question about Hoover Dryers
Hoover maxi 6 tv30 making grinding noise when in reverse
5 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: When loading the dryer (Hoover
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Based on your complaint it, certainly sounds like a relay,(typical), or it could be the timer motor. I have no way of knowing if it has a relay. Generally this is harmless.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Posted on Jun 21, 2008
  • 234 Answers
SOURCE: Hoover TV30 tumble dryer belt gone..how do I
On models that do not have disengageing clips for the top to be removed, you must remove the front (face panel) and this is usually done by 2 small screws at the bottom of the front panel. Then you tilt the front out and will be able to unhook the front from the top. Now, you need to undo a small bolt or screw inside between the top and the side panel (there is one on each side). Goodluck, Macgivor
Posted on Jan 02, 2010
SOURCE: my hoover maxi 6 reverse air tumble drier has no
The thermal overload has failed. Replace the heater assembly on the rear of the drier, under the metal cover.
Posted on Jun 05, 2010
emissionwiz
  • 75817 Answers
SOURCE: I have a hoover maxi 6 tv30 sorry the serial
most dryers regardless of the make and model use the same basic procedure to replace the belt, while u are in there make sure the drum rollers are in good shape. go to the link below instructions with pictures
http://www.diyprojectsonline.com/projects/interior/fix_dryer_belt.php
Posted on Sep 26, 2010
I hear a grinding noise whenever I put the car in drive or reverse, what could be the problem is it the transmission?
first thing i would be doing is if u can lift the frot of the car and with someone in the car e brake on and put it in drive and one person under it to hear where the noise is coming from as it could be a shaft or like colin h says it could be the trany ison its way out
Apr 23, 2014 | 2004 Mazda 6
Tip
Hoover Platinum Collection Carpet Cleaner with MaxExtract Technology making...
The cleaner does it's job well. Using on standard short carpet.
The problem so far is after 6-8 uses it started making a grinding noise when pulling backward.
Brushes still spinning just had the noise and the unit still functioned properly.
I only use it about every 3-4 months to clean 3 rooms.
The last use the noise got worse as it was making in forward and reverse motions.
The noise would usually start after using it for 5-10 minutes.
I figured it might be a slipping belt on the beaters and probably water was getting on the belt making it worse.
I removed the circular beater assy by just pulling it out.
Removed the round front beater by removing 3 screws, 2 at each end and one holding the belt guard on towards the middle. Once the beater is loose slide it out through the belt.
The front beater cogs for the belt had some black build up in between several cogs.
I cleaned the cogs very thoroughly, checked the belt for wear and checked the motor gear. They looked ok.
Assembled in reverse, did a quick dry test but didn't fill all the fluids to do a full test. That will have to wait till next time.
Please don't hold me accountable if you try this and break something, the cleaner is made mostly of plastic and the pieces can easily break. Don't try unless you are willing to take the risk, it may void warranty if it gets broken.
If problem still persists then will try using the 6 year warranty that it supposedly has... From what i've read it might be a pain getting it fixed under warranty.
Here are some visuals. http://s1139.photobucket.com/albums/n559/dmayfield1/Hoover/
fell free to contact for questions.
on May 27, 2012 | Hoover Vacuums
Kia sephia will start but when lights turned on door locks and starter motor engage?
you have wires reversed at the fuse block under hood, matbe had to replace sone of the maxi fuse's that bolt in?? the clutch is probable bad there is a test motor running emergency brake on then push clutch pedal in and try 1st gear and keep pedal down during this, go 1st gear the to reverse if wont go smoothly or grinds then most likly clutch throwout bearing is bad, maybe clutch cable is streched or not adjusted properly if it is mechanical clutch, depends on year and engine size
Jul 15, 2012 | 2001 Kia Sephia
My hoover dryer vhc392t makes a loud squeaking noise when in use can it be repaired
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 23, 2010 | Hoover Dryers
My hoover maxi 6 reverse air tumble drier has no hot air when drying. the filter care light is on. what does this mean?
Jan 27, 2010 | Hoover Dryers
My hoover makes a lot of noise, how can I make it quieter?
is it making a grinding noise? if it is check the brushroll, it might be siezed up and the clutch is grinding in an attempt to protect your belts.
Jan 09, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Floormate noise
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair. hoover.com
Oct 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
When loading the dryer (Hoover Maxi 6 TV30) a continuous 'buzzing' noise can be heard when the on switch is pressed. This can be heard for a few moments or a little long then everything is OK. Occasionally...
Thank you,
Dave E. (Illeagle)
Jun 21, 2008 | Hoover Dryers
Dryers Logo
52 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
