Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
I have a problem wi my pc motherboard speaker drives.Solve this problem
  • chinthaka Jayasinghe
    chinthaka Jayasinghe May 11, 2010
    whats the model of your Motherboard?
  • 416 Answers
Whats the OS you are using?
Posted on Jan 15, 2009
  • 43 Answers
Do like this Push Start>>>controlpannel>>>unitmanager.. If you can see A High lighter Yellow text with you audio cards name dubble click on it. if it's all gray taged you need to Install it. or Now it shall work
If not Search after driver to your audio card internet witgh your audio card model number...
Posted on Jan 12, 2009
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
My pc works only when I reset CMOS
Hi, Some of your BIOS settings are not 100% acceptable/compatible with your current setup. I would suggest that you set everything to default, save and close/restart. Another thing you can check is if the Lithium battery needs replacement. Normally it should read 3.0Volts. If the above does not solve your problem, you can consider other things: 1. BIOS update by flashing; 2. Processor to motherboard compatibility - try underclocking your processor by lowering its FSB; and/or 3. Memory to motherboard compatibility - try increasing your latency Good luck and hope this be of some help/idea to you. Post back how things went or should you need further information. kind regards.
Aug 25, 2007 | Abit IN9 32X-MAX (IN9 32X-MAX WI-FI)...
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
Need to replace cpu fan on Toshiba Satellite A85-S107 and can not get the laptop appart.
Remove the battery, unplug the unit.
  • Take off the hard drive cover by extracting the two screws that secure it and then taking it off. Take out the screw on the modem and wireless card cover and take the cover off. To remove the hard drive, shift it to the left to disconnect it from the motherboard and pull it out of the computer. Gently disconnect the Wi-Fi card antenna cables and take out the card. Extract the screws on the modem card, disconnect it from the motherboard, and then disconnect the cable to free it from the computer. Remove the optical drive screw, push the drive out of the laptop and then take it off. Extract the 15 screws out of the bottom of the laptop and turn the laptop over.
  • Open the laptop and fold back the LCD screen as far back as possible. Pry up the keyboard bezel (the plastic strip above the keyboard) by inserting a flat-head screwdriver or a spudger in the groove at the right side of the strip. Pull the bezel off the laptop. Extract the keyboard screws and fold the keyboard down over the palm rest. Release the flat cable that connects the keyboard to the motherboard and take the keyboard off the laptop. Remove the screws securing the LCD screen to the back side of the laptop. Disconnect the video cable and the Wi-Fi cable from the motherboard and remove the screws on the LCD screen hinges and then pull the screen off the laptop. There are four visible cables that are connected to the motherboard: the switchboard cable, the speaker cable and the touchpad cable. Disconnect all three. Take out the four screws from the top cover and pry the top cover off by running the flat-head screwdriver along the groove around the entire laptop and pulling it off. Now the laptop is completely disassembled to where the motherboard is exposed as the last remaining component.
May 05, 2011 | Toshiba Satellite A85-S107 Notebook
I have bought a Logitech speaker X-140, and tried to connect to my Packard bell ixtreme x6512 pc, which has 4 outlets, i have tried all of them, and I could not hear anything, but when i connect to my...
Hello
You should have your speakers plugged into output or green hole in back of pc.
Then you may need to go to control panel/sound/ and configure speakers for 4.1 or 5.1.
If you have only 2 speakers use the stereo setting.
If this still does not work try reinstalling the sound drivers for your motherboard or sound card.
Nov 26, 2010 | Computers & Internet
Where can i get a diagram of motherboard connections for acer 2480 laptop
Please follow the diagram of acer standerd motherboard below. From that photo you can solve your problem. 4381470.png
Feb 06, 2010 | Acer TravelMate 2480 PC Notebook
Sound dont work
Your potential problem is that your audio drivers are missing. You may get the drivers from your motherboard CD or motherboard manufacturer's site. But most of the times realtek audio drivers work for most of the system. You may get it from here. http://tinyurl.com/realtekaudio
In the above website, please select the required drivers viz., 2 or 6 or 8 channel drives. If you have just two speakers, two channel is your need. If you have a 5.1 surround or 7.1 surround setup speakers, you may choose 6 or 8 channels respectively. I guess this should solve your problem. And a simple request, please post more technical information about your problem to get more straight answers.
Regards..
NOTE: Choosing a 6 channel driver won't make your stereo (2 channel) speakers sound like 5.1 stereo.
Mar 17, 2009 | Computers & Internet
No sound on utube, or any website downloads. Have been trying to solve the problem for weeks, fiddling around last night now no sound in media player also, help driving me nuts
Maybe you need some audio driver, this driver drives your audio to be outputed to your speaker. audio driver are apparently included at your motherboard setupdisc.
Jul 12, 2008 | E-Machines etower 667ir PC Desktop
1 speaker only works?
If your speaker 4.1 then it will such problem until you special audio card. Or to solve this problem univerisal connector is available in market which connects both end of input of speaker is to connected to connector which in turn merge to single peice
Apr 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Ga-k8ns pro motherboard/ pc self build
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Mar 30, 2008 | Computers & Internet
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
204 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
