Question about Philips Radio Communications
Philips android headphones
I can get most of the prompts to work when the screen is awake, but not sure how to get the responses when the screen is asleep. I 've been using the manual buttons or waking the phone, which cancels the whole purpose of the remote. Also I can't get the phone to respond to the lower volume prompt of key press+hold. all the others work when phone is awake. It's just one tap of button then hold down, correct?
hogan doan
  • 227 Answers
SOURCE: Volume Button on steering wheel not responsive!
There is a metal dome under each button, some time they became warped or inverted and you don't get the actuating contact on the first push but if you keep on pressing it eventually contact will be made and whoalaa actuation happened. If you are technical incline you can replace it with a dome of similar size of a device you no longer have use for, like a remote control, an old car stereo or telephone...ect. Goodluck.
Posted on Mar 05, 2008
  • 319 Answers
SOURCE: tune in an older (1996/1997) model Philips tvwithout a remote
Most TVs have features that cannot be accessed w/out remote. Make sure you copy exact model number on TV then go online to seach replacement remotes
Posted on Apr 21, 2008
sdowney83
  • 62 Answers
SOURCE: Touch Screen not responding
KIng LeO>> Try re-calibrating the screen, settings>screen> then select "Align Screen". If after you do that, it still doesn't work, try a factory reset.
neldie>> Do a factory reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
Posted on May 18, 2008
  • 188 Answers
SOURCE: Hitachi TV volume won't work
Is the set in hotel mode?
Posted on Jul 24, 2009
SOURCE: Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Posted on Sep 24, 2009
Tabet shuts off when attatched to power cable
Try going to settings --> Developer options --> Stay awake
This way the screen shouldn't sleep when charging and you can see what is happening.
Also look at any power saving apps you have to see if they have setting to turn off/sleep when charging.
Dec 05, 2013 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
I forgot my passcode for my ematic tablet. how can i get around it
Hold volume down while you power on the device, and release it when you see the Android guy. *** You have to hold it down while you are powering it up, and don`t let go until you see the Android Guy. *** Then use the volume buttons to highlight factory reset (or something similar) and hit the power button to select it. Make sure you are plugged in while this is going on. Running out of juice during this process can really mess things up. After it is done let it sit, awake, for about 15 min at least while all of the apps reinstall themselves. Let me know if this fixes it for you.
Nov 21, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
The screen Won't "awake" after power off
check the data cable of your lcd try to replace the data cable it might resolve your problem.
Nov 19, 2013 | Philips 190CW
My Droid x hd is frozen and I can't get a response
Remove the backing of the phone and pull out the battery. Then put the battery back in and turn on the phone. If remove the battery isnt an option,
1. Turn off phone
2. Press and hold Power key + Home hard key to power on the phone and bring up a triangle with an exclamation point inside next to a green Android graphic.
3. Press Search hard key (only froyo 2.2) to show the Android recovery menu. ( for firmware 2.3 Gingerbread Press both Volume buttons)
4. Tap to select "wipe data/factory reset" (you can also use Volume buttons to scroll up or down in this menu)
5. Press Menu hard key under "Ok" screen prompt (camera button can also be used to confirm selection)
6. Handset will ask you to "Confirm wipe of all user data"
7. Select "Yes -- delete all user data"
8. Press Menu hard key under "Ok" screen prompt to start wipeout of phone, handset will begin to format handset showing progress with multiple lines of ellipses (....) (camera button can also be used to confirm selection)
9. Handset may take from 5-20 minutes to format.
10. When format is complete, press Menu hard key under "Ok" screen (or use the camera button) when prompted to reboot (Reboot system now will be highlighted)
11. You will see either an open box and the green android graphic when handset is rebooting (or the red DROID eye graphic).
12. Handset will be cleared of previous personal data, and you will need to start over with initial set-up process.
Sadly thats the only process which includes wiping contacts etc. and last alternative.
Oct 20, 2013 | Cell Phones
My dog chewed through the cable of my Philips shp2500 headphones, I have reconnected the all the wires but they still don't work. any help guys?
Feed the dog some good food next time...you might need to solder the wires and make sure the ground is not cross wired to any signal wires.
Dec 08, 2010 | Philips (33-01-031) Headphones
Philips SA60XX
Unfortunately - that is a common problem with mp3 players - the headphone jack itself is damaged (check a 2nd set of headphones just to be sure). Philips does not sell the headphone jack by itself, so it looks like it's replacement time - I would call Philips and see how much it would cost to replace the whole player (won't be much more than 100$ even if out of warranty). If you wanted to try to work with the existing player, you could twist the headphones until you find a position where both sides work - then keep it in that place, and don't move around too much.
-Tha Mp3 Doctor
Sep 27, 2008 | GPS
Philips FR965/17 Digital Audio/Video Surround Receiver
Well, if the headphones work,then the amp in the rcvr is working.
Make sure speakers are hooked up properly (Spr A, Spr B, etc.)
Be sure speakers are selected properly on the front panel.Look in the owners manual and see if its possible to reset the reciever.If this is an older unit, speaker relay may be dirty or defective or unit is in protection.If unit used to make a click after a few seconds when first turned on and now it doesn't, then the relay is not working.
Jul 21, 2008 | Philips FR965DHT Receiver
Sound only in 1 Speaker Instead of Two
not sure if this will help, go to your control panel and then to your sound and audio devices, on the volume tab check to see if both speakers are set to high on the speaker volume option
hope it helps
Jun 13, 2008 | Philips Dynamic Edge 4.1 PSC604 Sound Card
NO sound??
Make sure the volume is turned up sufficiently. If it is, then get it exchanged if still in warranty.
Apr 03, 2008 | Philips GoGear HDD1850 MP3 Player
Radio Communications Logo
35 people viewed this question
Top Philips Radio Communications Experts
Nyte_Ryder
normis101
Tom Chichester
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
