Question about Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black
No sound from one speaker , light does not come on
One speaker not working at all and not displaying a light
Klipsch Synergy Sub12 Subwoofer Speaker
If it's a new model you should send it back.
If it's not then it sounds like the thing that does all the work has gone. It will be found on a heat sink. Try replacing that.
Jan 25, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
Back surround speakers dont work.
If the display reads 2 chan then that means stereo, and the sound mode is not in any type of surround processing. For your surround speakers to operate you must select a surround sound mode.
Dec 06, 2009 | Audio Players & Recorders
'protect' blinked and then no sound or display
Disconnect the outside speakers "at the speakers" then turn back on. If the problem persists, disconnect the speakers at the back of the receiver and try again. If the problem stops "at the receiver" check your terminals and make sure no braids are touching each other. If the problem stops when you disconnect at the speaker, chances are good it's a bad voice coil from moisture. Most "outdoor" speakers with a brand name on them have a pretty good warranty. Good speakers have a 10 year warranty and the manufacturer will replace. If you still have an issue, post a comment and I can help you some more
Jul 26, 2009 | Sony STR-DE925
Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
May 02, 2009 | Koss KS3102 System
No sound from radio, display works, speakers work, wires correct
do you have an amp hooked up to your car stereo ?
Apr 25, 2009 | Car Audio & Video
03 chev silverado radio on but no sound
studying the radio schematics , i'm seeing a radio amp fuse under the hood ,in the main fuse box under hood , 30 amp , check that for starters , if the amp was out you would only lose sound , would like to get a fix ya vote , comment back because i have other thoughts on your schematics , and do you know if its the base model or premium sound , with or without cd ? , thanks .
Jan 11, 2009 | Car Audio & Video
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
No Sound
when the amp is turned on does the unit make a clicking sound a few seconds after the display lights up.
if not the amp's is not happy with it's power or could have a speaker short. Check the display for a fault warning.
Otherwise check you speaker connections.
confirm that and A and B main speaker buttons are correct.
Try some headphones, if you get sound out of the headphone things might not be too bad, if nothing is output remove all your cables and try again.
Yes I know that can be nasty, so label all the cables first.
Jan 21, 2008 | Yamaha RX-V1500 Receiver
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Feb 09, 2007 | Amphion Mediaworks T-365 System
Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black Logo
Top Griffin Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Griffin Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
