Question about Nordic Naturals Fish Oil Pet Dog & Cat Vitamin Supplement 8 oz Liquid
How much of liquid fish oil should I give my 63 lb goldendoodle
Also have 43 lb poodle
Half a pill or two drops depending on what kind of med it is
Posted on Jun 07, 2013
Would like to have torque specs chart please?
Hi there, the following information are for a 2004 Grand Am 2.2L, I hope it helps:
Timing Chain, Sprockets, and/or Tensioner Replacement
Tighten the chain guide bolts to 10 N·m (89 lb in).
Tighten the chain tensioner bolts to 10 N·m (89 lb in).
Tighten the oil nozzle bolt to 10 N·m (89 lb in).
Timing chain tensioner guide bolt to 10 N·m (89 lb in).
Timing chain bolts to 10 N·m (89 lb in).
Chain guide plug to 90 N·m (66 lb ft).
Timing chain upper guide bolts to 10 N·m (89 lb in).
Timing chain tensioner to 75 N·m (55 lb ft).
Camshaft bolts to 85 N·m (63 lb ft) plus 30 degrees.
Intake Manifold Replacement
Manifold Nuts and Bolts: 10 N·m (89 lb in).
Aug 30, 2014 | 2004 Pontiac Grand Am
Torque Settings for Honda CBF 600 rear disk and rear wheel? Thanks in advance.
Hope this helps:
Torque settings in lb-ft
Rear Wheel Nuts - 80 lb-ft
Pinch Bolt - 40 lb-ft
Front wheel axle pinch bolt - 16 lb-ft
Front axle bolt - 43 lb-ft
Front caliper bolts - 20 lb-ft
Oil filter - 7 lb-ft
Oil drain plug - 25 lb-ft
Oct 25, 2011 | Motorcycles
I need the torque specs for replacing the valve cover gasket on a 2001 chevy cavallier 2.2 liter 4cly. thanks
This should do the trick, torque to specs then additional 90 degrees turn on all bolts
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  • Use the following sequence in order to tighten the cylinder head bolts: Tighten
    1. Tighten bolt 1 to 63 N·m (46 lb ft).
    2. Tighten bolt 2 to 58 N·m (43 lb ft).
    3. Tighten bolt 3 to 58 N·m (43 lb ft).
    4. Tighten bolt 4 to 63 N·m (46 lb ft).
    5. Tighten bolt 5 to 63 N·m (46 lb ft).
    6. Tighten bolt 6 to 58 N·m (43 lb ft).
    7. Tighten bolt 7 to 58 N·m (43 lb ft).
    8. Tighten bolt 8 to 63 N·m (46 lb ft).
    9. Tighten bolt 9 to 63 N·m (46 lb ft).
    10. Tighten bolt 10 (stud bolt) to 58 N·m (43 lb ft).
    11. Then tighten all bolts an additional 90 degrees
  • Jun 28, 2011 | 2001 Chevrolet Cavalier
    I need the torque on a 03 ford ranger 3.0lit. cylinder heads
    59 ft lb
    loosen 360 deg
    34-40 ft lb
    63-73 ft lb
    start in center and work your way out.
    Oct 22, 2010 | 2003 Ford Ranger Regular Cab
    Need torque specs for brake caliper bracket bolts.2000 grand prix
    Hello and welcome. here is the torque specs for the bolts.
    Caliper Bolts
    85 N·m
    63 lb ft
    Caliper Bracket Bolts
    180 N·m
    133 lb ft
    Caliper Bolts
    85 N·m
    63 lb ft
    180 N·m
    133 lb ft
    caliper brake bracket bolts torque to 180 n.m or 133 ft.lbs
    Jul 26, 2010 | 2000 Pontiac Grand Prix
    Hp color LaserJet 3700 jams 70# uncoated letterhead stock
    Hi manitou344:
    Here is some info that might help you.
    Table 1-8. Tray 1 paper sizes1
    Media Dimensions Weight or thickness Capacity
    Minimum size paper 76 by 127 mm
    (3 by 5 in)
    60 to 163 g/m2
    (16 to 43 lb bond)
    100 sheets
    (75 g/m2; 20 lb bond)
    Maximum size paper 216 by 356 mm
    (8.5 by 14 in)
    60 to 163 g/m2
    (16 to 43 lb bond)
    100 sheets
    Minimum size glossy
    paper
    76 by 127 mm
    (3 by 5 in)
    75 to 120 g/m2
    (20 to 32 lb bond)
    Maximum stack
    height: 12 mm (0.47 in)
    Maximum size glossy
    paper
    216 by 356 mm
    (8.5 by 14 in)
    75 to 120 g/m2
    (20 to 32 lb bond)
    Maximum stack
    Minimum size
    transparencies2
    76 by 127 mm
    (3 by 5 in)
    0.12 to 0.13 mm thick
    (4.7 to 5 mils thick)
    50 sheets
    Maximum size
    transparencies2
    216 by 356 mm
    (8.5 by 14 in)
    50 sheets
    Minimum size
    envelopes
    76 by 127 mm
    (3 by 5 in)
    60 to 90 g/m2
    (16 to 24 lb bond)
    10 sheets
    Maximum size
    envelopes
    216 by 356 mm
    (8.5 by 14 in)
    60 to 90 g/m2
    (16 to 24 lb bond)
    10 sheets
    Minimum size label 76 by 127 mm
    (3 by 5 in)
    75 to 163 g/m2
    (20 to 43 lb bond)
    50 sheets
    Maximum size label 216 by 356 mm
    (8.5 by 14 in)
    75 to 163 g/m2
    (20 to 43 lb bond)
    50 sheets
    Minimum size
    cardstock
    76 by 127 mm
    (3 by 5 in)
    135 to 216 g/m2
    (43 to 43 lb bond)
    50 sheets
    Maximum size
    cardstock
    216 by 356 mm
    (8.5 by 14 in)
    135 to 216 g/m2
    (43 to 43 lb bond)
    50 sheets
    This printer can
    detect transparencies that were not designed for use with HP Color LaserJet printers.
    Jun 30, 2009 | HP Office Equipment & Supplies
    I need a diagram of a 1995 ford escort engine
    96 escort 1.9L
    Engine Components
    Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
    (2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
    (2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
    (3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
    Feb 24, 2009 | 1995 Ford Escort
    Need to know the torque sequence and ft lbs for a 1998 chevy cavalir 2.2 liter thank you
    I found two pieces of information, but no picture showing the sequence, but hopefully this will help.
    For the 2.2L engine. First Pass Long bolts 46 ft. lbs Short bolts 43 ft. lbs Final Pass Tighten all bolts an additional 90 degree turn.
    Jan 01, 2009 | 1998 Chevrolet Cavalier
    Nordic Naturals Fish Oil Pet Dog & Cat Vitamin Supplement 8 oz Liquid Logo
    113 people viewed this question
    Top Nordic Naturals Pets - Others Experts
    Ross Keen
    Tom Chichester
    Ruth summersides
    Are you a Nordic Naturals Pets - Other Expert? Answer questions, earn points and help others
