Question about Sony FD Trinitron WEGA KV-SW29M50 29" TV
My sony trinitron standby light blinking twice and wont turn on. sometimes it can on but cannot watch longer cause it will turn off itself...
Its start because of lightning.. After that day my tv get the problem...
    Top Expert:
  • Sony Master
  • 14,553 Answers
The 2 blinks is a error code, it usually will NOT point to specific parts but will indicate area the problem is in, I would suspect it will be power supply related.
If you call Sony or a authorized dealer they can access the data base and see what it means-----almost certainly the set will have to go to a shop for repair.
I did in our shop recently have a Sony with a start up problem and when I found the code it pointed to 3 small parts in the power supply and said replace all 3 (about 10 dollar part cost) and when installed set worked fine.
This can be found and fixed, cost will of course be a concern.
Posted on Dec 05, 2012
  • 115 Answers
SOURCE: my sony trinitron tv wont
Try a reset:
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
If that doesnt solve it, you will need a repair.
Posted on Aug 10, 2010
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
bernardlunda
  • 318 Answers
SOURCE: sony trinitron wont turn on red light blinks standby
your tv has a power supply not working. plse take it to a shop and have it repaired.
ask the tenchnian to check the ht high tension voltage of 95-105 volts, if this is not been produced from the supply then that confirm it being fault.
he should check the semiconductor of the supply.
your supply will stay longer if you power it using a 115 volts on the in put of the supply not 220 volts. because 115 is the minimum and 220 volts is the maxmum.
okay
Posted on Jan 03, 2010
freetek
  • 5568 Answers
SOURCE: Canno turn the tv on.
You probably have a main or high voltage power supply problem; the latter produces the 20,000 plus volts for the CRT and gets its voltage from the main supply. It's difficult to say which is at fault without a few measurements.
Posted on Feb 14, 2010
Sony TV turns off immediately after turning on
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
Jan 13, 2013 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Standby light blinks twice approx every 2-3 seconds tv won't turn on
Visit this site 'Electro-help" for details. Type in the site name either to Google or Yahoo search box, and click search. It has all details about tthis fault, and repair.
May 11, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony trinitron tv wont turn on and standby light keeps blinking
Hi
Blinking of standby light in Sony sets are fault indication. The number of blinks occurs at one instance must be counted. With that bumber I can reach to the fault section inside its circuit; sometimes to the exact fault point too. Just turn OFF the set, and turn it ON, and count the number of blinks at a time [do this atleast 3times and make it sure]; and inform me by Fixya. OK.
Jul 07, 2011 | Televison & Video
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV shuts down
check for D616 open or Q603 short.
sometime D501 leaky.
Apr 22, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sometimes tv won't turn on and standby light blinks and sometimes it works perfect
The key here is the number of blinks of the standby light. This is an internal diagnostic code. Please provvide that count and I should be able to suggest possible fixes.
Thanks,
Dan
Apr 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony kw-655 turns off by itself
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 03, 2017 | Sony Televison & Video
Tv wont turn back on
TV will be on for 2 hours sometimes, or 20 minutes then goes off, standby bottom is flashing. and keeps doing that over and over.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-SW29M50 29" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
