Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I would like to find out what the diagram for the Walbro carbuetor shows for the adjustments i don't know which screw is air or fuel!
I know the larger screw is the idle,but the two other screws only have an "H" & an "L". do I screw them both in all the way then back them out slightly? If I had a diagram I could get this baby going again!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
You can find plenty of info about carb adjustments on youtube and google
Posted on Feb 22, 2014
  • 10865 Answers
SOURCE: Chain moves while idle
Hello there. Regarding the bar oil, many loggers plan their work so that they are out of bar oil at the same time that they quit for the day because bar oil has a tendency to leak. Another method that has some success is to mix your bar oil with a heavier oil but the trade off might be less lube getting to the chain when you need it.
Regarding the chain moving in idle, this is another common problem. You can usually slow the idle down until the chain stops, as you indicated, but I too have had chain saws where I finally just decided to live with it and be extra attentive to what was going on.
Posted on Jun 11, 2009
  • 4088 Answers
SOURCE: "L" adjustment screw on the carburator
L is for idle speed mixture and H is for full throttle mixture. Adjust H, when engine is warmed up, with full throttle--adjust for high speed, but 4-stroking which should smooth out just as soon as you start cutting. Allow to idle and adjust L for smooth idle, but rich enough to allow the engine to 'follow the throttle'. Set idle speed screw to just allow the chain to stop moving.
Posted on Sep 13, 2009
  • 20 Answers
SOURCE: john deere chain saw CS 56 idle adjustment
check the choke lever rod possable loose or off
Posted on Feb 11, 2010
puertobori
  • 7733 Answers
SOURCE: poulan pro pp4218 .... only
Look at eReplacementParts.com and the parts diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
chargerhp
  • 814 Answers
SOURCE: 16'" Wildthing wont Idle after turning the "t" throtle screw
you only screw it in till it moves the throttle plate. Now start it and set idle
Posted on Dec 31, 2011
Carbuetor adjustment air and fuel mixture on poulan pro pp330
For initial start: Turn low and high out 1 full turn.
Sep 05, 2014 | Garden
I need the settings for a 24cc walbro carb
Charlie:
Gently turn both screws in all the way, and turn each one out one and a quarter turns. the machine should start. adjust from there making small adjustments to either the fuel or air needle valves.
May 08, 2014 | Garden
B&S fuel feed pipe connector problem
Try using an easy out (special tool for undoing broken threaded tubes and fittings) or a flat blade screwdriver and stick it into where the broken part is. Try to unscrew whats left of the broken tube.
Sep 17, 2017 | Briggs Motorcycles
My Husqvarna 128ld trimmer will run but only at low rpm. I cant find a tool to adjust the carb. If I choke it 1/2 it will run at higher rpm, I suspect a fuel problem. It started in an instant.
If it is a newer trimmer it has a little plastic deal on the adjustment screws to prevent adjusttment.(epa). You have to break that off then a screw driver will work. Some are tough, turn hi speed screw counter clockwise it will rev
Sep 26, 2010 | Husqvarna 28cc Gas Line Trimmer
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman gas blower model #358.797130. replaced gas line and filter.Had to take gas tank out to connect line. Cannot find how to connect the carbuetor to stay on the gasket. diagram in the book doesn't...
Probably a couple of screws that you took out to access the carb from inside the air filter housing. Probably Torx head screws. You line up the carb and put the air filter housing back on over the carb, lining up the holes in the engine block.
Does this look like the answer you were seeking? Or did I mis-understand?
Nov 01, 2009 | Craftsman 4 Cycle Blower/Vac
Has no power
adjust the carbs fuel-air ratio and see if you can't get it to rev up
Jun 18, 2009 | Electric Lawn Mower
Engine will not throttle up
the red and white screws are the air and fuel mixture needles they may need adjustment if you are getting plenty of fuel to the carb. note that newer walbro carbs these mix set screws can only be adjuted very little. they will break if you twist to much. but firt when you took the carb apart was the fuel metering diaphram crisp or was it still flexable? ( black gasket thing under side cover . it has a small metal botton in the middle of it. if this does not flex freely then you need a walbro carb gasket set. mabe 5 to 10 bucks.
Jun 08, 2009 | Ryobi Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
188 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
