Remove monitor stand
How to remove the pedastal on a mecer monitor when wall mounting it
mpersaud
  • 97 Answers
SOURCE: How do I remove the stand?
hey,
i do not suggest that you try to take apart the stand from the monitor because it is a desktop, hence the name, supposed to be on flat sturdy surfaces, unless the manual gives permission i think thats a bad idea.
kind regards
Posted on Jan 06, 2008
SOURCE: Removing the mounting stand
You've probably worked it out by now, but I thought I'd post the answer anyway, for anybody who may come looking in the future......
If you look at the back of the monitor you'll see two screws which can be easily removed. What's not as obvious is the THIRD screw. To get at it you need to remove the top plastic section of the stand; I carefully inserted a blade screwdriver in the groove, then gently twisted it in a few places. There's no need to dismantle the rest of the base.
It was my 12 year-old son's eagle eyes which spotted that third screw. My contribution to this part of his MAME project was figuring out how to get at it.
I hope that helps someone.
Colin
Posted on Jul 30, 2008
SOURCE: Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Posted on Dec 05, 2008
SOURCE: I want to remove stand 'holder' so I can mount on an Atdec V-AT-DB Dual Focus LCD Desk Mount
This is an old post but for others with the same problem;
There are two plastic snap on covers, one on each side of the stand hinge. Slide each small cover in towards hinge. Pry up each plastic cover. Remove hinge screws, hinge, replace screws, replace plastic covers.
Posted on Feb 20, 2009
  • 81 Answers
SOURCE: how to remove stand from a samsung syncmaster 910mp
It's usually 2 screw at the base of the TV, at the rear. Loosen or remove the screws and the base should slip right off
Posted on Sep 01, 2009
Viewsonic monitor manual
Yes. The base stand may be removed. The unit is VESA mount compliant with 4 holes. 100mm x 100mm.
Aug 24, 2014 | ViewSonic VX2025wm 20.1" LCD Monitor
Desktop Stand ,any ideas ?
  • You can get a universal wall mount if the stand is no longer available or you cant find one
May 10, 2014 | Philips 190WV
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
I have mounted the tv on the wall but can not remove the stand?
if it s a pedastal stand like in the picture there will be four screws holding it inwhere the two poles insert in the back of the tv
Mar 03, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
HELLO I HAVE A SAMSUNG 24 INCH MONITOR. MODEL P2450H I WOULD LIKE TO REMOVE THE STAND FROM THE UNIT AS I WOULD LIKE TO WALL MOUNT IT, THANKS RICHARD KEENE
The stand is secured to the back of the monitor with screws.
Your wall bracket may need modifications if the mounting holes on the monitor.
Dec 04, 2010 | Computers & Internet
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
