Question about Precor 9.31 Treadmill
The treadmill shuts down as I go faster
My wife runs on it and it is, fine she weighs about 145 lbs, the treadmill shuts down when I run on when the speed gets around 4.7 MPH, I weigh about 190 lbs.
    Top Expert:
  • Precor Master
  • 12,223 Answers
This happen because the lack of LUBE maintenance schedule
Lube with 100% silicones or wax see your instr. manual
2) Lube the rollers bearing. with wd-40
3) test the drive belt motor.
4) Test the input voltage motor, if there are the motor need repair
see my personal TIPS for motor help
5) Test the output board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Posted on Dec 05, 2012
5 Suggested Answers
SOURCE: Treadmill works just fine for me. i am 100 pounds,
Did you find a solution for your issue? I am having the same problem.
Thanks
Posted on May 09, 2011
maxtreadmill
  • 832 Answers
SOURCE: My Precor 9.21 si Treadmill shuts down upon
Hey Doug,
Just wondering has this unit ever had the running deck flipped over if not this may be sighs of worn deck or belt or both! What is starting to happen is that at the higher speed the unit is starting to draw more current, so the motrol control board will sense this and will shut down so it won't damage either the motor or board. What starts as an occassional shut down will progressively become more frequent. Simple test is put your hand palm down between the belt and deck,if you feel uneven ridges then the deck needs to be flipped over and when you pull out your hand out and their is a black sooty film on the back of it ,then that seals it this means that the composite material is being shaved off. Most likely the belt will have a smooth glazed feeling in the middle part of it. and well also need replacing.
Posted on Mar 14, 2010
taran_2005
  • 10515 Answers
SOURCE: I have a 2006 Precor
Kindly provide few more details :-
1. If you run it at a lower speed, have you ever noticed an issue with the machine?
2. Is it an intermittent or eveytime you increase the speed to above 5 mph, it would stop?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
  • 42 Answers
SOURCE: I am 230 lbs. and when I try to run intervals on
hi it seems like the running belt is too loose try tighten it. you should be able to lift the belt up 2 to 3 inches if more then def tighten the belt. after this if the problem is still there then the belt on the motor needs adjusting.
Posted on Nov 21, 2010
When I get on treadmill it slows down andjust about shuts off. Im 265 pds, My wife gets on @ 160 pds the treadmill runs fine. I ADJUSTED THE BELT LOOSER AND IT STILL RUNS THE SAME. WHAT CAN I DO TO CORRECT...
Loose is not the answer. Proper lubrication and correct tension adjustment is the answer. I don't know how many HP the motor is for, but for 265 pds it should be at least 3HP.
Put the speed at about 3MpH and while walking, make a small jump on the belt to ensure that it is properly tensioned. Needless to say that the belt must be well lubricated. If you see that the belt tends to stop when you make the jump, turn both allen screws exactly the same amount clockwise. Half a turn might be enough. When you're satisfied and the belt doesn't seem to stop, give both allen screws another half turn clockwise.
All that as long as the treadmill is capable of handling your weight.
Jan 17, 2014 | Proform XP 580 Trainer Treadmill
I am either walking or running already for a few minutes and the treadmill part of the treadmill just stops suddenly but computer part still shows all right info. My wife weighs 130lbs. and doesn't have...
If the machine is over 7 years old then you need to replace the walking belt. Most proform treadmills are not meant to be run on, especially by anyone over 220lbs. Forget what the manual says, they are a terrible company.
Sep 07, 2017 | Proform XP Weight Loss 620 Treadmill
We have a Sole treadmill F85 purchased about 3 years ago with lifetime warranty. When my son would do speed workouts (he is a large kid, about 215 lbs), the machine would shut off after running a 5-minute...
DEAR
THIS MODEL IS WEAK FOR HIGH WEIGHT PERSON AND YOUR ROOM IS NOT YOUR PROBLEM BUT YOUR TREADMILL CHOOSE IS YOUR PROBLEM .
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 15, 2017 | Exercise & Fitness
The treadmill speed is faster than reallife speed. I can easily run 7 minute miles on the roads (not racing, just running) and my wife is an eight minute metronome. But on the treadmill if I set it below...
the speed of treadmills are based on the companies regulations and are machine made. so they might not be 100% accurate. a treadmill is a simulated devise so it is never the same. var fctb_tool=null; function FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']); delete document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976'] var fctb_tool=null; function FCTB_Init_6836227ebca14782a6c9f0284529fff9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6836227ebca14782a6c9f0284529fff9(document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']); delete document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']
May 05, 2011 | NRS Sole S77 Treadmill
What is the weight limit on a treadmill
hi good day..When you run on a treadmill the impact is 2 1/2 times your body weight. The impact from walking is considerably less. Therefore individuals who weigh in over 200 lbs need to consider a treadmill that can withstand the additional impact. Most treadmill manufacturers overstate their weight limit by as much as 50-75 lbs.
Treadmills for Users Over 250 Pounds: If you are in the 250 lbs range you better find a model that claims to at least handle a 300 lbs user. Look for models that have a deck that is around and 1-inch thick. A ½-inch deck may break from users that are hefty..
Apr 19, 2011 | Health & Beauty
Is there a weight restriction ?
It is not a restriction. It is a recommended limit of 300 lbs. See ProForm 695 LT Treadmill
If you weigh more than the limit, the machine will feel, and be, unstable. You could also harm the motor over time.
Dec 28, 2010 | Proform 695 LT Treadmill
Treadmill slows suddenly and when i step off it starts again. only happens to me.
hi it sounds like the belt is too loose, i had the same problem when the wife uses the treadmill works perfect, untill i step on it really slows down and once i step off it runs fine. so i tightened the belt just a fraction and now works fine. check your instruction manuel it will explain how to do this. normally its two screws at the backend of the roller. hope i have helped.
Nov 15, 2010 | Proform XP Weight Loss 620 Treadmill
Proform 760 shuts off after running for 15 minutes. Needs to cool off before it can be reset
my wife has a proform 490gs that keeps shutting off after about 40 minutes by tripping the breaker. what is causing this.
Oct 30, 2009 | Proform 760 CrossTrainer Treadmill
Precor 9.31 Treadmill Logo
192 people viewed this question
Top Precor Exercise & Fitness Experts
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
