My parties can't hear me on my tb20el true blue bluetooth
I can hear them, but they can't hear me. could there be a deflect in the bluetooth device?
  • 101 Answers
Yes problem is with mic
Posted on Sep 21, 2009
Pioneer trouble shooting
You should confirm whether your Bluetooth Device is working. Check your Bluetooth Headset with some other Bluetooth compatible device and if it works there, your Phone is not set properly to use that Bluetooth headset.
You may call helpline number of Manufacturer for more help.
Apr 26, 2014 | Car Audio & Video
I have explorer 240. I paired my device to computers bloutooth. everything was ok. But now the other party can't hear me. I tryed to pair with my cellphone, and there was the same problem... Is there...
It could be that your unit is defective and may need to be replaced but here is some information for you to check out from the user guide:
1) Callers cannot hear me, or I cannot hear caller/dialing tone.
The headset is not turned on or the headset is not connected to mobile phone. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on.
Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Your headset battery is drained. Charge your battery using the AC power adapter supplied.
The listening volume is too low. Press the volume key up (toward the earloop) to increase the sound heard in the headset.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
Blue tooth buton not active does it have blue tooth or is that just a button
Try installing the bluetooth driver from the driver disc that you should get when you bought the laptop. If it says bluetooth device is not found, push the bluetooth button once and try again. If it still says that the device is not found, then most probably your laptop have no bluetooth.
This is true for some Acer laptops that I've meddled with. I did what I said, assumed that there's no bluetooth device, only to have it confirmed by the owner that the seller already mentioned that his model have no bluetooth.
Apr 11, 2010 | Acer Aspire 4730-4947 Notebook
Setup for trueblue/bluetooth, Tb20el
start in the off position press and hold the talk button and you will hear a tone continue to hold for another 7 seconds (10 seconds total) then the light should be flashing blue then red it is now in discovery mode now take the divice you are trying to pair it with and do a search for blue tooth devices. once it is found you may need a password it is 0000 as is the default password for all blue tooth devices hope this helps.
Apr 30, 2009 | Radio Communications
Need passkey to connect my tb20el bluetooth to my phone
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
Apr 14, 2009 | Motorola Mobility H700 Wireless Headset
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Mar 05, 2009 | Acer Aspire 5610-4648 Notebook
Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Dec 19, 2008 | True Blue TB-50CR Bluetooth Headset
Cant find bluetooth device
be sure to hold down the button on the bluetooth till it blinks red and blue together, than make sure the phone bluetooth is on and than press find device. should solve your problem
Apr 27, 2008 | Motorola Mobility RAZR V3
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
