Question about Microwave Ovens
The fan run with door up where is door switch
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
Most of them in the opening of the door itself--usually have to get at them from inside of the unit--most are a level or leaf type switch--door being closed hard or a lot can damage or move where it is mounted--most shops can get at this and it should not be a major repair.
Google the model number of your unit with "problems" and see what you find, if lucky you may find a You Tube video for this fix.
Posted on Dec 05, 2012
Blower fan run when i shut the door and never shuts off what could the problem be mo#rcs10ts
Some brands of microwaves will do that when you have a bad door switch or the door/switches are out of adjustment. In most cases the actual microwave isn't running just the light and fans but it does need corrected.
Mar 31, 2015 | Amana Microwave Ovens
GE Profile XL1800 light out and fan starts running when door is closed
It is not the fault with the fan but the trigger to the fan is shorted. It can be the DOOR SWITCH or the Transistor switch from the board. A fault or error on the processor cannot be ruled out. Clean the main board and reset.
Jan 31, 2013 | GE XL1800 1100 Watts Microwave Oven
The fan runs when the door is open just like it does when it's running. When the door is shut and not running the fan is off. I opend/shut the door 3 times firmly like the GE rep. told me to but it still...
Hi.
Disconnect the oven from power and allow cooling down. Most GE have temperature controlled fan system.
The Fan is controlled by main pcb and powered along the line passing through the door lock switch, with circuit supplying power to the magnetron and turntable motor.
The fan is also operated directly by the control board.
If the turntable was also running, then the door switch is shorted. In that case the magnetron may be working as well, better not to start the microwave oven.
If only the fan is running, then the main pcb must be replaced, or the damper motor relay must be replaced.
Call GE and arrange repair, the unit is faulty.
Apr 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Dacor DMT2420 fan, light and turtable motor run continuously when the door is open. I have unplugged the unit to reset it with no help, another on-line forum expert suggested checking the door switches...
If the cooling fan, light and turntable run continuously when the door is open, but not when it is closed, your secondary interlock (bottom door switch) is shorted (always on).
Even if it's shorted, the actuator button (usually red) will still move up and down when you open and close the door.
It will need a new door switch.
See the service manual here. See our file on door switches here.
Jan 04, 2010 | Dacor DMT2420SS Microwave Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
Sharp R-1750 Microwave
the door switches need adjusting. remove casing and adjust door switches
Jan 25, 2009 | Sharp R-1750 Microwave Oven
Sharp R1490 when door is open fan runs...
check door switches and control circuit.
Nov 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
