Question about Video Game Consoles & Games
Playstion 2 steering wheel not workin on simpsons hit and run one flashing light please help
    Sergeant:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 193 Answers
You have to click on start on a normal control. If that don't work you simple Ask in a shop were they fix game like that.
Posted on Dec 06, 2012
2 Suggested Answers
  • 661 Answers
SOURCE: just bought second hand steering
I'm pretty sure it is because just like a regular controller, it has to be synced to work properly.
Posted on Feb 11, 2011
Brake lights do not get brighter on my GMC 1996 sierra on the driver side only nor does my turn signal. I have changed the lights with no luck. Please help.
Your bulb contains 2 filaments; one for your brakes and one for your running or tail lights. If you try the hazard lights and the tail light flashes, the bulb and its wiring are ok but the control system is faulty.
The most likely cause of this problem is the directional relay which controls the brake, flasher and directional lights. Failure can cause a multitude of problems with these lights.
The part is located below the steering wheel inside the lower dash towards the left side of the wheel. Check around as this part is a bit on the expensive side and has updated part numbers from the original.
I hope this helps with your question.
Feb 26, 2015 | GMC Cars & Trucks
Password uploadsnack simpson hit and run
how can i get password for the simpsons hit and run pc game
Jan 03, 2014 | Fox Interactive The Simpsons: Hit and Run...
Turn signal switch repair
The steering column wheel has 2 pins pushed into the back side of it and as you turn the steering wheel making a turn, the pins slide over the humps of the blinker signal. As you return the wheel back to center to drive straight, these pins then hit the humps in the turn signal and push the turn signal back to the original position. It sounds like one of these pins fell out or broke off. You need to pull steering wheel and check to see if these pins are still inserted on the back side of the steering wheel.
Sep 29, 2013 | Mitsubishi Montero Sport Cars & Trucks
I dont know what is the password for the simsons hit and run encrypted file
It is because you haven't bought the game simpsons hit and run. If you have bought it from a market, check that the disk contains the serial code or not. The serial code is usually in a TXT file named Serial ID, Serial Code or Serial.
If you can't find it, you should go to the market and buy original version of the game.
Jun 28, 2012 | Fox Interactive The Simpsons: Hit and Run...
My Simpson Eziset 550 won't drain. 2x flashing lights and continual beeping. HELP URGENT PLEASE :-(
Hi just read your posting.Now in your posting you said there were 2 lights flashing.What lights are flashing?Also on a sticker at the back of the machine there is a model number.Could you please reply back and let me know the model number and which lights are flashing.Looking forward to your reply.
Aug 18, 2010 | Washing Machines
We have 80,000 miles on our 2000 Millenia with the following problem, 1.Flashing engine light, 2.Runs a little rough at idle, 3.The steering doesn't feel right..not stable or hunts?
The flashing light and rough engine means a spark plug(s) misfire. I've had that issue before. The steering could be a few things. The ball joint or wheel bearing might be broken or the axle could be broken. I replaced my wheel bearing (pot hole) and the steering was fine. However, I also had to replace my steering rack prior to that incident.
Nov 09, 2009 | 2000 Mazda Millenia
Air bag light flashing
the most common cause of the airbag light is a defective rotoating ribbon contact under the steering wheel that connects the airbag to the steering column wiring harness, the contact is called the clock-spring contact.
Mar 31, 2009 | 2003 Nissan Maxima
No tail lights
you most likely have a short somewhere. some vehicles were designed with radio controls on the back of the steering wheel im not sure when they started doing it but thats all i can think of for the radio
Nov 13, 2008 | 1989 Toyota Camry
Flashing air bag light on a 99 crown vic ex-police car
yea its what connects the steering wheel with a ribbon for a solid contact and its is always being tested to make sure there is a connection.
Nov 13, 2008 | 1999 Ford Crown Victoria
Video Game Consoles & Games Logo
51 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
