Turning off and clicking - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The clicking may be a power relay in the set but to help further I need to know the brand and model number.
Posted on Dec 05, 2012
Touchpad working
Q: How do I turn the touchpad or pointing device on or off?A: Follow these steps to turn on or turn off the touchpad and optional pointing device.
  1. From the Start menu, click Control Panel.Note: If your Control Panel is in Category View, click Printers and Other Hardware.
  2. In Control Panel, click or double-click the Mouse icon.
  3. In the Mouse Properties dialog box, click the Device Settings tab.
  4. Click to select the device you want to turn on or turn off, and then click Enable or Disable.
Found on Gateway website :)
Aug 14, 2013 | Gateway Ne56r34u 15.6inch Laptop Black
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
How to turn off power save mode
Navigate to the control panel and double click power options.
Under the turn off monitor select never.
Click apply then OK.
Thumbs up!
damnor01
Jan 30, 2011 | Dell E153FP 15" LCD Monitor
How do i disable windows restore
Steps to turn off System Restore
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the System Restore tab.
  3. Click to select the Turn off System Restore check box. Or, click to select the Turn off System Restore on all drives check box.
  4. Click OK.
  5. When you receive the following message, click Yes to confirm that you want to turn off System Restore: You have chosen to turn off System Restore. If you continue, all existing restore points will be deleted, and you will not be able to track or undo changes to your computer.
    Do you want to turn off System Restore?After a few moments, the System Properties dialog box closes.
Jan 11, 2011 | Microsoft Windows XP Professional SP3 Full...
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
I have broken.openco after scanning with malware bytes. i have scanned several times with this but keeps comming back how can i get rid of this?
Try to download and install AVAST antivirus Home Edition. It is free. Besides, avast has an option to scan at boot time so it can detect and delete viruses and malwares before they can cling to your system memory. You can download it here.
Jun 06, 2010 | Computers & Internet
1999 Isuzu Rodeo Won't Start
does it click multiple time or just once
many click click click click means you have a dead battery
one click means you have a starter circuit issue good luck
Jan 27, 2009 | 1999 Isuzu Rodeo
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
My camera is making a clicking sound when i turn it on
this could well be the VR (vibration reduction system) there should be an option to turn it off in the setup
Apr 26, 2008 | Nikon COOLPIX S200 Digital Camera
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
