Question about HP Photosmart Pro B9180 InkJet Printer
Leaking magenta ink onto output HP 9180
I have been away and just switched my printer on again. I replaced a couple of cartridges incluing the magenta. Now when I print it leaves magenta blobs across the page. I have cleaned and realigned the heads but the problem persists...any ideas??
chris
Hi all. After running the clean heads and extended clean heads routine about 5 times i have resolved the issue. Took some time but all seems well now.
Posted on Jan 12, 2009
26.001 error hp 4000
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)
Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.
You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.
If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.
If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)
Good luck !
(My money is on bad compatible or refilled yellow ink cartridges)
Apr 12, 2013 | HP Designjet 4500ps InkJet Printer
I have rectently replaced the inks, but it wont print the black parts, any solution?
If you are having issues on an HP officejet printer, go to the menu, click "Diagnostics," then print the "PQ Troubleshooting Pages." If black ink does not print, go to "Disable the Cartridge" and switch the magenta and black cartridges on the menu. Then, print the pages again. If black ink does not print, then the problem may be the toner cartridge.
http://printers.iyogi.net/hp/install-hp-...
Jan 23, 2011 | Office Equipment & Supplies
Why is the magenta ink getting everywhere: all over the inside of my printer, all over my paper, everywhere?
Check your print heads and the cartridge. replace the cartridge. if that doesn't fix it, call hp RIGHT AWAY. Leave positive feedback!
Jan 13, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Keeps asking for ink and it has ink
Try removing, and then reseating the MAGENTA cartridge.
If you replace the MAGENTA toner-cartridge, does the problem go away?
Jul 30, 2010 | Xerox Phaser 8560DN Laser Printer
Have replaced Magenta twice in two weeks. Does not recognize it.
There are only 2 reasons why this problem happens to your printer:
1) This usually happens if your printing heavy graphics.
2) You are using HP refilled ink
Take note HP always suggest us to always replace your ink with original HP ink cartridge
Aug 26, 2009 | HP Photosmart D7260 Printer
Says there is more than one magenta cartridge installed
Try replacing the cartridges one by one, one at a time to find out which cartridge is causing this problem. May be there is a magenta chip on one of the othercartridges.
May 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printer Cartridge Leaked
clean the belt with a VERY SOFT cloth, there is a release lever to access the back of the belt. Replace magenta cartridge
Mar 11, 2009 | HP Color LaserJet 2600n Printer
HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Photosmart Pro B9180 InkJet Printer Logo
201 people viewed this question
Seeker5211
Seeker5211
