Question about Leica Geosystems Disto D330
Leica Disto D330 error message 220
Meter comes on and laser shines but when you try to measure it either turns off or error message 220 appears.
What does error 270 mean?
There is no error code 270 listed for a Leica Digital DISTO D3a 100M Laser Distance Meter.
Are you sure that's the code?
Or do you have a different make or model of laser distance meter?
Sep 06, 2016 | Leica Digital DISTO D3a 100M Laser...
My leica disto A5 is not measuring more than 2.5 meters , if i measure more thank 2.5 meters it give info 255
First, insert brand new Duracell batteries. Then you might try cleaning the optics with a Q-tip and some rubbing alcohol. A 255 error indicates that the unit is not getting a strong enough signal, essentially that not enough of the laser is getting back through the optics to the sensor. If these don't make a difference, contact the dealer you bought it from, it may be eligible for the Leica repair program. (good luck if you bought it off ebay or from an unauthorized dealer)
Mar 06, 2015 | Leica DISTO A5 Rangefinder
Does not measure distance
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
Oct 18, 2014 | Leica Disto A6 Laser Distance Meter
Code error 279
Remove old batteries, put in new batteries, clean off lens.
Jun 10, 2014 | Leica Disto A6 Laser Distance Meter
Leica disto
Low battery. Mine does that when batteries are too low to operate the laser.
Aug 20, 2013 | Optics
Leica Disto D3a shows ERROR 220
I had this exactl problem and resolved it by replacing the batteries
Feb 19, 2013 | Leica Digital DISTO D3a 100M Laser...
Always get error 279 on my Disto Classic
Put in new batteries and clean lens and calibrate if it has that function. If that doesn't work, Type the " Leica Disto A6 Laser Distance Meter user manual" and it will bring up sites to manual.
Jun 28, 2011 | Leica Disto A6 Laser Distance Meter
After I changed the batteries for my Disto A6 the screen stayed blank. I see the laser beam and beep. but nothing in the screen.
MY LEICA DISTO D5 SCREEN DOES NOT LIGHT UP ALTHOUGH THERE IS LEISER AND READING. HOW DO I RECTIFY THIS.
Jan 18, 2011 | Leica Disto A6 Laser Distance Meter
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Aug 12, 2009 | Leica Disto A6 Laser Distance Meter
Leica Geosystems Disto D330 Logo
260 people viewed this question
Top Leica Geosystems Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Leica Geosystems Measuring Tool and Sensor Expert? Answer questions, earn points and help others
