Question about Porter Cable Cable Brad Nailer and Compressor Combo Kit CFBN200A
Not enough PSI
Hi my porter 2hp 6GL compressor doesnt reach high psi.it only reaches to 40psi. it does not pass that qty.it is a 150psi. also it doesnt shutoff, if any body knows anything i"ll appriciate thank u.Alex
    President:
  • Porter Cable Master
  • 1,388 Answers
I have worked on several of these little compressors and have found that they suffer from early failure of the cylinder and piston. Unplug compressor and remove cover. Move piston to top of cylinder and check for scratches neer top of cylinder. If scratched, air is bypassing ring and will not reach cutout pressure. Parts are available at your local dewalt parts store or at www.toolpartsdirect.com. However, you could check a few things for other problems that I have seen on low pressure compressors. While the compressor is running spray soapy water on the airlines and drain valve to make sure that they are not leaking. A small leak will prevent the unit from reaching cutout limit. Check for belt slipping. You will see black powder/dust if belt is about to fail. Parts are not expensive. Good Luck
Posted on Jan 12, 2009
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
My c2000 wk1 will only reach 40psi
This problem could be caused by 3 different things.
1) The one way Check Valve from the pump to the tank is damaged and allowing the air to go in and out.
2) The piston ring and cylinder sleeve are damaged.
3) The valve plate has a broken reed.
You will need to remove the covers and head to check number 2 and 3..
Oct 13, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Compressor relief valve opens 150lbs on my d55141
That is the compressor's holding capacity 150psi. Therefore, the cut-out pressure has been reached. The safety valve opens to relieve the excessive psi. Compressor should come on at 120 psi.
May 15, 2012 | Dewalt d55151 factory reconditioned emglo...
Porter cable the compressor regulator is always at 0, the tank is at 150psi but no air at the outlets
Always at zero,like the regulator is broken?
I would assume that you never set it to whatever
pressure you want to use
Jul 31, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My porter cable pancake PSI 150 keeps running will not shut off
The compressor has a max psi setting of 150.If the pressure is not reaching this or is only stabilizing at a low pressure you have an air leak around a gasket somewhere.If it is reaching 150psi and not shutting off your pressure switch is bad.Replace it.Check your owner's manual for a part number or go to www.factoryauthorizedoutlet.com to find the part.
May 05, 2011 | Porter Cable Air Tools & Compressors
We have the pressure set at 60 psi and when the pressure is reached the motor keeps running. I have drained the tank hoping that would do something but no change. Just keeps running though the desired...
Sounds like a pressure switch to me. I would like to ask you a few more questions, let me ask you this, is the tank set at 60 Psi or the regulator? You can email me at phoenix.repair@hotmail.com for faster response time.
Oct 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Does not auto turn off
Sounds like the pressure switch is shorted together. Unwire the switch and see if it shuts off.
Apr 08, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Porter-cable compressor stops and restarts at about 60psi
You prolly have a leaky gasket in the main valve. Air is leaking and causeing it not to go about 60psi, you probably have it set to reach a high PSI but since the leak is not allowing it reach above 60 it keeps cycling trying to get above it
Aug 27, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Porter Cable Cable Brad Nailer and Compressor Combo Kit CFBN200A Logo
280 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
