Question about Nostalgia Electrics CCP-509 Popcorn Maker
Where to buy a xb6020 motor
Need to replace electric motor the gears are slipping
White Mountain 69204 ice cream motor gear slips
Sometimes the gears in the unit become worn and have to be replaced. This might help.
White Mountain Ice Cream Freezer Motor Repair
Sep 04, 2013 | White Mountain F69206X 6 Quart Ice Cream...
I have an oster a5 clipper. The motor is running but the blades do not move .What can be the problem? What part do i need to buy?
Its possible the gear wheel which is located under the name plate has slipped, if you remove the plate, lever and drive link the gear will pull off.
Inspect the teeth on the gear if there are signs of damage or slipping this is likely to be the problem.
Sep 06, 2011 | Oster Golden A5 2-Speed Universal Motor...
My car is having trouble starting up the starter is making fkat buzzing sound any ideas?
Sounds like a slipping pinion gear. Remove starter solenoid assembly and put on the kitchen table, old newspapers for protection are optional. The pinion gear is the one on the end of the starter motor shaft that is driven forward to engage with e toothed edge of the flywheel. It should free wheel in one direction and lock solid when reversed. The locking clutch mechanism its what supplies the motor's rotation to the flywheel to crank the engine over. If the pinion gear clutch is slipping the motor makes a whizzing sound as the shaft spins within it. You can buy a new pinion gear cheaply. Whilst the motor is out buy a refurbishment kit ($10) for the solenoid consisting of contact striker plates and plunger . This preventative measure will avoid any hassle in this department for many years.
Sep 27, 2010 | 2004 Ford F150
My CDX-636 has a mechanisim to lift and lower the
My Sony CDX-636 has a mechanisim to lift and lower the CD reading carriage. It consists of a small motor and two nylon gears. the smaller of the gears has stripped a number of teeth which makes the carriage move up and then slip back. I need a new gear wheel. where can I buy a new gear? I am living in Palmdale, california
Feb 06, 2010 | Sony CDX-636 CD Changer
Window help
Sounds like the gear drive in the small electric motor that moves the window up and down has broken. You will need to replace the electric motor. You can't just buy the gear for it unfortunately.
Aug 30, 2009 | 1995 Ford Explorer
Motor runs but blade does not move. Sounds like gear stripped or maybe clutch slipping.
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Jul 17, 2009 | Remington 111409 - 01 6" Branch Wizard...
Windows not working
remove motor and check gear it could be slipping and just buy gear save money ,plug motor back and if motor runs could be gear make sure you have 12 volts at plug and hold gear with pliers and listen for motor running
Jul 09, 2009 | 1991 Mercury Grand Marquis
Gear slipping in dewalt dw056
Those gears are only held on the motor with their tight fit, if yours is slipping that easily the motor will have to be replaced. The new motor will have that gear on it.
Apr 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Stripped gear in motor
I just spoke with Nostalgia Electrics Customer Service and they stated that they do not sell replacement parts of any type for this piece of CR4P! Seriously... why would anyone design a nylon gear in between two metal gears unless it was designed to fail.
Feb 18, 2009 | Bond Helman Old-Fashioned Movie Time...
Kitchen Appliances - Others Logo
157 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Wayne Fellows
Wayne Fellows
Christopher Smith
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
