Question about Canon Pixma iP3600 InkJet Photo Printer
Canon ip3600 printhead stuck inside case & wont move
Just bought a supposedly new printer off ebay and the printhead is stuck inside the casing and wont move and is making horrible noises when I switch the printer on and the error light starts to flash. The print head was pre-installed which if brand new would not be the case as I already have an ip3600 & had to install the printhead myself. I dont think it has been used as there is no ink anywhere inside & is as clean as a whistle. I am wondering if he installed the printhead wrong & hence the problem and decided to sell on ebay? He aslo stated no returns in his listing and listed it as new, unwanted present. Any help will be most appreciated..
worldvet
  • 859 Answers
SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
Posted on Jun 07, 2008
  • 111 Answers
SOURCE: Canon i960 prints but no ink on page-new printhead (not clogged)
Sounds like the print head is no good. This happens. Here's a link to a site that sells them reasonably.
Posted on May 25, 2009
  • 37 Answers
SOURCE: Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
jay767
  • 386 Answers
SOURCE: I installed a new Ink
Hi Good day!! well i know that you can fix it. 1st off all is there any message error in your printer? if none then we will try to troubleshoot it in the printer spooler. Printer spooler is located in the services. please try the following.
1. turn off in a few seconds and then turn it on see if the ink cartridge is moving.
2. Click "Start
3. Click "Setting
4. Click "Control Panel"
5 Click "Administrative tools
6. Click "Services you should be on the services box now.
7. in the service box find "Printer Spooler
8. Click "Printer Spooler" all you need to do is to restart the printer spooler Stop and then START it again.
Try to print now hope your ink cartridge move..
ReGARDs
JR
Posted on Oct 07, 2010
ginko
  • 19396 Answers
SOURCE: My problem is with canon
Hi.
This is not an all-in-one inkjet that you can service at home. This is a large format printer, and print head replacement requires adjustment. The job is suitable for a technician or for an experienced DIY user that can service large format printers and copiers.
After replacement the print head rail must be greased and print head calibrated. If this operations are not getting done correctly, the printer may result damaged.
About error code:
The error code given is incomplete
Error:03800200-2802 means "Incorrect Print Head Installed".
Error:03010000-2820 means "Unable to adjust printhead registration"
If you have first error, then the printhead is either faulty or the part is wrong.
If you are in case two, try performing print head registration, if that does not work, then the print head has not been installed correctly.
The calibration procedure must be performed each time the head is replaced:
4.5.2 Procedure after Replacing the Carriage Unit or Multi Sensor
a) Multi Sensor Recalibration
Since multi sensors have individual electrical specificity, the following are recalibrated at the factory, namely,the optical axis of the sensor, the sensor gain for measuring the printhead height and color reproduction.
Accordingly, carry out the following adjustments in the service mode whenever replacing the carriage unit or multi sensor.
* The multi sensor reference plate must be replaced at the same time whenever the carriage or the multi sensor is being replaced.
- Service mode : SERVICE MODE > ADJUST > GAP CALIB
- Service mode : SERVICE MODE > ADJUST > SENSOR CALIB
Test chart : CL-7( Tool No. : FY9-9323 Use anew chart.)
- Service mode : SERVICE MODE > ADJUST > PRINT PATTERN > OPTICAL AXIS
Media type : Photo glossy paper
Media size : Media having a width equal toor larger then that of 24inch-size paper
If that does not work you need to proceed to wire roller adjustment. The adjustment is usually not needed if you replaced only the print head, and not the carriage:
b) Adjusting the wire roller
To prevent the wire roller mounted on the carriage from contacting the duct and others during carriage operation, perform the following adjusutment whenever tou have removed or replaced the carriage unit. This adjustment is not required when you have replaced only the multi sensor.
* Make adjustments with the carriage lock released.
* Make adjustments with the tube disconnected from the tube guide.
(1) Loosen the two screws[1]
(2) Turn the gear[2] until the lift cam flag[3] reaches the position shown below.
* Bottom position where the sensor[4] light is blocked by the flag (lowest position to which the carriage may descend)
Regards.
Ginko.
Posted on Oct 31, 2010
Just stopped printing one day. My HPOfficejet 6000 Model E609a just wouldn't print black. I bought a new black cartridge and still not printing. Ran a self test and didn't print tha
I have had the same thing happen with a Canon. I was talking to someone 1 day & they had heard of a case where an electronics wiz had the same problem. He went troubleshooting & found a counter connected to a switch very deep inside the printer. He shorted the switch out & the printer worked fine!! The only problem is I can't remember any specific details regarding the maker/retailer etc.
Sep 26, 2014 | Office Equipment & Supplies
How Do I remove the casing on a Canon iP3600 Photo inkjet printer? I have removed the drip tray for the ink nozzle and cleaned it but, with little foresight, now found out I cannot replace it correctly...
Hello
To reset the waste ink error you will need to download a reset program. This resets the printer counters back to zero and the printer will work again as normal. You can download this reset program from our website.
<a href="http://www.wasteinkpads.com/">waste ink reset</a>
Thank you.
Aug 29, 2013 | Canon Pixma iP3600 InkJet Photo Printer
Canon pixma ip3600 blue colour cast
I don't get true B&W but only 1/2 a Gnats knacker off it, if you send for a test print from say Ilford you'll notice that it's not B&W but a warm tone very slightly sepia.
I use cheapo inks bought on eBay so none of the settings in software are of any use. I disable any attempt by the software to influence the printer and do the same in the printer settings window. I then alter the colours using the sliders in the Manual section of the colour/intensity to the colour that I see on my screen and save the setting in the profiles section.
I use the iP3600 and have found it very good indeed, after lots of experiments I've settled on a sepia tone reminiscent of Sodium Sulphide but without the nasty smell.
Jim
Jun 23, 2012 | Office Equipment & Supplies
Canon IP3600, error # 6A80. Can't fix the issue
I have pixma ip3600 canon printer, been used 8months working fine, but today, when I turn on just wait for little whileand the amber light turn on, and when I open thetop cover the printer head won't move at all, please show me how to fix the problem. thanks. Email ( bui_lac972@yahoo.com )
Apr 13, 2011 | Canon PIXMA iP3600 Photo Printer
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Sep 27, 2009 | Canon PIXMA iP3600 Photo Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma iP3600 InkJet Photo Printer Logo
191 people viewed this question
old marine
old marine
