Question about GE Washing Machines
Tub stuck on shaft
I am replacing the transmission in my GE-WPRB9220 wash machine. I have removed the 1-11/16" nut, but I can not get the tub to slide off of the transmission shaft. Any suggestions?
  • Jay H Dec 05, 2012
    I do have the white ring off. The nut is off. I have soaked the area with both WD40 & CLR. I have also tried the hammer method, but still no luck.ahve also
    President:
  • GE Master
  • 1,922 Answers
Take a piece of 2x4 lumber and after soaking tub bearing that the tub is mounted on have someone hold the tub/motor combination up off the ground and take the 2x4 and hit the top agitator shaft so as to drive it off the tub,you have to hit them HARD sooner or later it will fall off the shaft its just rust holding it on
Posted on Dec 06, 2012
5 Suggested Answers
  • 240 Answers
SOURCE: kenmore 80 series leaking....plastic tub cracked on the bottom
if you removed the large nut (round with four notches cut in it ) then tub should be free. sometimes these "rust together" on the hub. wd40 and a hammer to knock it free. try rocking the basket to break free. you did remove the tub ring(white plastic part on top), right?
Posted on Apr 28, 2009
  • 12 Answers
SOURCE: Bearings Worn - I have
If is the nut that's on the bottom of the tube, use a piece of hardwood a hammer to slowly remove it, but counterclockwise.
Posted on Jul 23, 2009
  • 151 Answers
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Posted on Dec 24, 2009
  • 1937 Answers
SOURCE: Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Posted on Jan 26, 2010
Tub removal
that's a part of the basket that the agitator slides into. From there, the tub is supposed to lift but its somehow seized by the shaft from that is apart of the supports assembly. Good luck with that.
Apr 01, 2014 | GE GTUP270EMWW Washer
Ge transmission shaft wobbles
The tub bearings are worn out, you will have to replaced the outer tub to repair this problem. Good luck. Here to help
Feb 04, 2014 | GE WDSR2080D Top Load Washer
Vbsr3100dawn washer water leaking between tub hotpoint
Hi, there is a tub seal (WH02X10032) that can be replaced, however, the tub nut generally requires the GE tool to remove. The nut is hex shaped, but is made of a pretty soft alloy so it can break if you use a regular wrench. Once the tub is out, you may also find that you need a new tub nut and split ring.
Apr 20, 2010 | Hotpoint VBSR3100D Top Load Washer
Jan 25, 2010 | Kenmore 22422 Top Load Washer
I have a GE Select Top loading wash machine that is making alot of noise during the spin cycle. 99/2000 model
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | GE WBSR3140DW Top Load Washer
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
363 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
