Question about Whirlpool Dryers
My dryer heats up and after a few minutes it stops turning but still gets hot. What could the problem be? its a whirlpool cabrio model wed6200sw1.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
It will stop tumbling but still heats?
Posted on Dec 06, 2012
  • rcg18 Dec 06, 2012
    Yes that is exactly what it does. It still heats but stops turning after a few minutes. And it keeps blowing the thermal fuse. I have already replaced the thermostat cut off. And the thermal fuse blew again. Any help would be appreciated.
  • Richard Roth
    Richard Roth Dec 06, 2012
    So you are going to need to replace your element. The element should NEVER heat unless the motor is spinning--- there is a centripetal switch inside the motor that will not allow the heater to complete the circuit if the motor is not rotating at full speed. If the element is touching the case or grounded out it will heat up regardless of what the motor is doing. Check the element to see if it is grounding. Here is the element if you should need it.http://bit.ly/TVLlQQ
  • 767 Answers
SOURCE: Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Posted on Apr 08, 2010
reg501
  • 413 Answers
SOURCE: whirlpool dryer stops after 5 minutes
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Posted on Jun 02, 2008
mgprice
  • 744 Answers
SOURCE: dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Posted on Jul 24, 2009
  • 523 Answers
SOURCE: Whirlpool cabrio gas dryer does not turn gas on to
first change the ignightor if its a glow plug
Posted on Jul 01, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio model WED6200SW1 clothes dryer
There are two thermistors (thermal sensors) in this dryer; one is the outlet thermistor located on the blower housing and the other is the inlet thermistor located on the heating element housing as an integral part of the high-limit thermostat.
These thermistors are negative coefficient type and monitors the dryer temperature on their locations according to their resistance which varies inversely with the temperature. The resistance drops as the temperature rises and rises as temperature drops.
One or both of the thermistors has an open connection or high resistance which makes the electronic control board thinks that the dryer temperature is low no matter how high it is. The electronic control board then doesn't cycle the heater relay and continue to turn on the heating element. The dryer temperature continues to rise and this blows the thermal fuse.
Make sure the thermistors are connected snugly. Remember that loose or open connection means high (infinite) resistance which makes the electronic control thinks of low dryer temperature. Measure the resistance of each thermistor then refer to the tables below. Replace the thermistor if the resistance reading doesn't comply with the table.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 02, 2011
I have the whirlpool cabrio wed6200sw1 dryer and when i set the drying time to 45 minutes drying time,the timer count's down in about 20 minutes and ends the cycle, got a F25 code when I ran diag's
f25 is a bad thermisiter,find the tech sheet in the dryer and it will tell you how to read out the thermisiter,if the thermisiter is good then you have a bad computer board.
Feb 12, 2018 | Whirlpool Dryers
Cabrio electric dryer WED6200SW1 runs but will not heat up. What do i need to do? And how?
hay Aric , it sounds like you have bad element or fuse . test as follows unplug wires to the element and turn unit on if you get 120v to the element replace it if no power then it got to be a fuse or the door switch test them for continuity , good luck APPLIANCES R EN
Feb 24, 2013 | Whirlpool WED6200S Electric Dryer
How to replace blower wheel on whirlpool cabrio dryer
The threads are backwards. The pulley end of the motor has a flat spot on it where 7/16 wrench fits. I use a wrench to hold that part down and then I basically shove a flat piece of iron actually ot it a tub nut remover tool into the bales at the 3 o'clock position and slam down the a 12 pound hammer. Sometimes the pulley on these breaks. Most times though if you get mean with it you can get it off there in one piece. The cabinet might be fancy but it has the same setup and any roper/kenmore.whirlpool dryer motor with filter in the top. My crappy home movie of how it all goes down
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Clicking noise in blower wheel area
Remove the rear cover and get the filter chute off there. Clean her up. This dryer is no different than other dryers with filter in the top.
Cabrio service manual
Cabrio model WGD6400SW gas dryer runs but not heating at all. have cleaned it.. still no heat. This happened the same day we had a service tech look at our cabrio washer. Have not had them for 3.5 yrs...
I agree. It's rotten to have someone check out your product and then have it stop working. You probably have a problem with your ignition panel.This is the part of gas dryers that gets hot. When it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Jul 31, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Our Whirlpool Cabrio Elecetric dryer will not start. Model is WED6200SW1. We had just finsihed drying a load and put a 2nd load in, but it won't start. All the light come on. Could it be a sensor...
it could be that or it could be the start button, you can check the button by adding a jumper in the wires that go to it,, this should be done as a check and not left that way,, for safety
Jul 03, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Apr 08, 2010 | Whirlpool WED6200S Electric Dryer
Dryers Logo
435 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
