Question about Optoma EP755 Multimedia Projector
Optoma ex532 power light flashes and lamp light is not on
  • 4 Answers
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
SOURCE: optoma ep 706, lamp lights on,replaced lamp, still not working
moz-screenshot.jpgmoz-screenshot-1.jpghello,
This is an unfortunate incidence and i will send you the serviceable manual of your projector if you can send me your contact email address to my email.Yes ,there are instruction to follow to replace lamps in projector if not you might miss it. First you must confirm that the lamp is OK from the vendors you purchase before anything.
Bye.
anytony2004@yahoo.com
Aniekeme Anthony.
I
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
duane_wong
  • 6826 Answers
SOURCE: I have an Optoma H31
When the voltage goes to 250 vdc does the light light at all? Does the lamp itself, when removed, have continuity? If not, then the lamp may need replacing.
Or, the mode of the projector needs to be set so that multimedia inputs are accepted.
Good luck on this repair.
Posted on Oct 15, 2010
SOURCE: Hi, I have an Optoma 1690 which has strobing -
I also problemma which has strobing - standby/on, temp and lamp lights.This happens as soon as it is plugged into power.
Posted on Jan 28, 2011
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Lamp fault
Look at the ballast module. It controls the lamp operation.
Dec 05, 2013 | Optoma GT750-XL - DLP projector - 3D...
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Power light flashes
Hi Sir,
did you solve with your trouble?
perhaps the trouble is on the mainboard,
Dec 12, 2011 | Optoma EX532 DLP Projector
Powers on but no lamp light
Did you find a solution to this problem? I have the same thing with my Optima 1690...
Jul 09, 2009 | Optoma EP750 Multimedia Projector
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Jan 07, 2009 | Optoma EP755 Multimedia Projector
No power to optoma ezpro 739
check the door(cover) of lamp not closed firmly open it and close it firmly.
Sep 22, 2008 | Optoma EzPro 739 Multimedia Projector
My MovieTime die after two LED flash for a second after power up.
Check the Lamp and replace if that is damaged.send for repairs if the Lamp is okay.
Viren
Nov 26, 2007 | Optoma MovieTime DV10 Multimedia Projector
Optoma EP755 Multimedia Projector Logo
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
