Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
TV turns on and there is sound (white noise type) - audio will not come on - checked sound menu and mute button for correct settings - no luck on audio
    Top Expert:
  • Sony Master
  • 75,289 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Posted on Dec 05, 2012
3 Suggested Answers
rongxin
  • 57 Answers
SOURCE: Sony TV no sound
first open the rear cabinet,if you a tester first test your speaker both side if open ,second check the voltage of the resistor if has a 12 volts going to audioutput.and third if speaker and resistors are good.you to replace the audio output.
Posted on Jan 11, 2009
josema_sv
  • 512 Answers
SOURCE: I can't access the Audio
That means that output varies with with volume control, but you have to set speaker off to activate the audio output, this is done in this same audio menu.
Posted on Feb 20, 2011
Sony wega 2009 tv. No Audio but picture. Internal speakers on, no luck. Tried external speakers, turned off internal speakers,still no luck. Suggestions? Is it audio components or board bad?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Feb 05, 2017 | Sony Televison & Video
Can't get sound from my Olivia 232-32" TV how can i fix it
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electro-medical.blogspot.com/
Dec 28, 2016 | Televison & Video
No sound on tv.All cAbles are correctly connected.Volume set on 70.Dstv cable connected correctly and sound settings on 90
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 23, 2015 | Televison & Video
I have Philips Flat Tv model # 42pf7320a/37 ..I have a clear picture but no audio, just white noise and static.
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 23, 2015 | Philips 42PF9630A 42 in. Plasma Television
Olivia tv has no sound but see picture what does this mean?
  • Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2
    Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3
    Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • May 07, 2014 | Vizio L32 32 in. LCD HDTV
    No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    Have lost sound on my dish TV and mute button is not on
    Is there sound using the set top box? Try a different remote if possible. Last but not least, Call Tech Support.
    Oct 14, 2013 | Televison & Video
    My 52" JVC D-ILA tv has absolutely no sound on it.
    Feb 15, 2018 | JVC Televison & Video
    Mute is on when I turn my vizio on. How do I
    The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
    Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
    Model 60PL9200D/37 no sound
    What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
    For a red, white, and yellow cable:
    I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
    Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
    If the connection is good,
    Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
    1. Press the 'MENU' button on the remote control.
    2. Press the cursor up/down to select SETUP and press the cursor right.
    3. Press the cursor up/down to select SOURCE and press the cursor right.
    4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
    5. Press the cursor up/down to select AV1 and press the 'OK' button.
    6. Press the 'MENU' button to exit the menu.
    Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
    For HDMI,
    The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
    Answer
    • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
    • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
    • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
    • For detailed information, please refer to the user manual of the accessory device.
    Apr 07, 2008 | Televison & Video
    Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
    24 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
