Question about Cameras
B4.09.24.1 current driver not working on skype following skype update
    Master:
  • Cameras Master
  • 663 Answers
You can do system restore to revert the settings of your computer before the update.
Here's what you need to do:
Click on Start > Programs > Accessories > System Tools > System Restore
Once the restore screen shows up, select on the date when your camera was still working great. Launch the restoration.
You can also update the driver of your camera. You can go to the website of the manufacturer to look for the driver which is compatible with the current operating system that your computer is running. However, you can also an a software to update all drivers automatically if you wish to. You can use RadarSync.
David
Posted on Mar 06, 2013
Why my skype vidoe call not working.
Hello here is a fault finder guide from skype:
https://support.skype.com/en/faq/FA1267/i-set-up-video-in-skype-for-windows-desktop-but-it-doesn-t-work-what-can-i-do
Here is the asus homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=A7V333-X&p=1&s=10
Make sure all the drivers is updated, by selecting your windows system.
Is the driver for the webcam, installed or updated ???
Look also here:
https://support.skype.com/en/faq/FA3681/making-a-video-call-windows-desktop
Do you see the webcam inhere ???
Update also skype to the latest version.
Good luck
Jan 31, 2013 | ASUS A7V333-X (A7V333-X/L) Motherboard
Skype doesn't show me online to my friends
Try updating skype on both machines and make sure there is enough band width to work. If you use a Mac, why not use Facetime.
Jul 11, 2017 | Skype IM
I am having trouble with my skype video. When I make a call I can see and hear them, but my party cannot see me. I have a logetic webcam250. Please help!!!!!
You should install the drivers before you try to operate the webcam, unless the instructions state otherwise. If the drivers are not installed, unplug the webcam and install the drivers, and plug the web cam back in when promoted. If you have the drivers installed already, or can confirm the web cam works, open up skype and navigate to tools then options. Once in the options menu go to the video settings tab. In the "select webcam" drop down menu select the webcam of your choice.
It's also possible you are using an older version of skype that my not support new protocols for video, OR it's possible you are using a new version of skype which doesn't automatically start video. If you are using an older version of skype (current version is 5.1) update to the later version. If you have the latest version, you may need to manually start video chat. When you start a call, look towards the lower area of the screen for a button that says "My video" and click on it. This should start the video chat.
Hope this was of some use!
Mar 29, 2011 | Skype IM
Skype comes up and says my camera is not supported.
  • Extract from Skype Help
  • "Most PC-compatible webcams should work with Skype, although some older models may not. Make sure you download and install the most recent drivers for your webcam (you can get these from the webcam manufacturer’s site). Or, you can buy a webcam that’s guaranteed to work seamlessly with Skype from the Skype Shop.
  • Make sure both you and the person you are video calling are using the latest version of Skype. To check what version you have, click Help > About Skype.
  • Please check that your computer hardware configuration supports video calls – the recommended system requirements are a 1 GHz CPU, 512MB RAM, a video card with at least 16MB of memory and a 512/256kbit (down/up) broadband internet connection.
  • Check that your video device supports DirectShow 9.1 standard (WDM is currently not supported).
  • Make sure that you have the latest version of DirectX. You can download DirectX if you need it. After installing it, please go to Start > Run and type dxdiag. In the window ensure you have DirectX9.0c or higher. Sometimes the installation fails to update the version and in these cases please contact Microsoft for support."
Gearhead Support
http://www.pcgearhead.com/cams.html
May 03, 2010 | Gear Head WC330I Webcam
Microsoft Lifecam VX-3000-unknown video error on Skype
I tried the skype link given in Solution #1.
None of Skype's suggestions helped.
The problem child: Windows 7 (all updated) and current Skype.
I installed DirectX per Skype's suggestion.
Also found this link to MicroSoft driver for W7:
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=LifeCam&name=68A-00001&os=Win7_3264&lang=en
It's working at the moment. But the camera was working previously with this setup. Time will tell.
Nov 03, 2009 | Logitech Webcam
Skype shuts down when I enable the video on Skype. I tried using an older version of Skype but still encounter the same problem, any ideas out there
With updating SKYPE your firewall must be updated as well.
Exit/Close your current Skype by clicking in system try Skype icon (down near the right corner green spot)
and choosing “Quit” from there if needed.
Open firewall, in programs, deletes Skype.
Run Skype and allow connecting
This also affects SP2 users who should follow above procedure.
With SP2 firewall.
Disabling external firewall will enable XP firewall by default.
So if you disable any other firewall XP firewall will now block your connections.
So remove Skype from XP firewall program list as well
dont forget to vote fixya rating
Sep 13, 2009 | Logitech QuickCam Pro 9000 Web Cam
Voip 080 wont work with my updated skype
close the voip philips application from the task bar. Then do the same for skype. Now Start Skype again followed by the voip software. If that doesnt work uninstall both software and reinstall installing the voip 080 first, then upgrading the skype. You may still receive a warning at first but it will work
Apr 24, 2009 | Philips VOIP0801B/79 IP Phone
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
