I dont have a ( black ) color even when i clean head and cartrige .. also i chang the tranfer wire .. please help me with that thank's
    Problem Solver:
  • 15 Answers
Try to remove black cartrigde make sure ink is compatible to your printer then wipe gently wet cotton shirt or tissue in the film of cartridge after wipe out and clean the surface insert it try to print.
Posted on Dec 07, 2012
  • 5 Answers
SOURCE: printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
Posted on May 06, 2007
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
  • 79 Answers
SOURCE: Black Ink Cartridge
The problem with this printer is that the Printhead is buried deep in the printer and is very difficult to get to. One trick that someone tried is to purchase print head cleaning solution from a website such as www.fillserv.com and fill an empty cartridge with the solution. Then constantly do head cleaning until the cartridge is empty and then try printing. You need to be good at refilling brother LC41-BK cartridge which is very difficult in the first place. I don't recommend it because it may cause more damage. When my Brother printer head got clogged I just threw it away. Its just not worth it in my opinion but at least you have an option.
To learn how to refill a brother cartridge go to this website.
http://www.refillinstructions.com/Brother/B4.htm
Thanks for reading
Hope this Helps!
Posted on May 01, 2008
mrmx2333
  • 56 Answers
SOURCE: won't print red color
push and hold the power button for 35 seconds this will reset the color fill it should work
Posted on Dec 19, 2008
  • 7 Answers
SOURCE: canon pixma 3000 is not
it is very important to use a good quality ink, you can buy ink and toner for very cheap online and that would cause malfunctions in the printing process. visit sites like www.yahootoners.com to get the best quality ink at the best possible price.. you could also try cleaning your printer with a special type of cloth, here is a link to explain this in more deatails. http://www.ubergizmo.com/15/archives/2006/01/sticky_paper_for_printer_cleaning_by_elecom.html Tonerdude
Posted on Jun 04, 2009
When I print the Black ink does not print on page at all. All of the colors cyan, magenta and yellow are fine. I haver replaced the Black Cartrige and Run the printers cleaning cycle several times.
maybe you run out of ink for black, try to use other ink, if its still the same then their a stockup ink on your head of the printer and better to replace it. I think once you purchase an ink cartridge of cannon their is also printer head included. Hope it helps thanks.
Sep 19, 2011 | Brother MFC 490cw Color Inkjet...
Don't print in color
It's your printer head problem. Your printer head is now block. To remove the problem try to follow the proces:
1. Take some amonia solution ( amonia30%+ water70%) in a plastic seringe.
2.remove cartriges from cartrige holder.
3. Then set the seringe nipple in one stick (that is into cartrige holle all time while cartrige is push).
4. Then push the solution in to the black plastic stick.
Use these proces 5/6 time one after another to a black stick.
I think you may relive from your problem.
Thank you
Jun 16, 2011 | Epson Stylus C82 InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
My printer
sure....did you do a clean and alignment service after changing that black cartridge?
Aug 03, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Mfc 210
if the MFC is a brother..your print head could be dead.
Jun 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black ink problem
It could be also the clogging of nossels in color Balck?!
For this purpose you need a special Cleaning solution, wich you
put first in the balck cartrige and start 2x cleaning(when cleaning you should observe if the balck ink is realy transported through the tube !!).Then you shut down your printer for about 24 hours.After that you clean also
for 2x times and check after that the nossels printing test. If not all nossels are free you should repeat the hole thing once again....till the nossels are free.Another problem i observed at my printer is that at some CISS ore kompatible cartriges the rubber-sealing get used with the time and do not seal enough the
conection from cartrige to printer-head and they **** only air...
For this problem i sugested a solution ..see epson stylus 1400
i hope i could help
Apr 13, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Won't print black
just try with tet page of printer and also reinstall the driver and see. bye
Sep 26, 2007 | Epson Stylus Color 740 InkJet Printer
jasbo
jasbo
