Question about D-Link DIR601 WirelessN 150 Home Router and DLink DWA125 Wireless 150 USB Adapter Bundle
Why do i have to rest my wifi Dlinks router daily so it can connect to my phone?
I hugesnet internet i never had a problem before i use to have AT&T. does that have anything to do with it?
My phone micromax hd's WiFi is not working. I had reset my phone but still facing the same problem. My phone's WiFi get connected to the router but can't access the internet. Help me plz!
If you can get connected to WiFi but don't have access to internet, try accessing at some hotspot - site wit internet without access code.
If still ghet no connection, you might have a problme with the inalambric card of your phone, which of course is part of the phone's circuir board.
In this case, you should take your phone to a repair servie to diagnose it.
Oct 23, 2015 | Computers & Internet
How can i get my smart tv to connect to the internet it is already connected to my wifi but when i click to connect to the internet it comes up no internet connection?
Check to see if your laptop or phone gets online via wifi to see if wifi is on the net, and try rebooting your wireless router by unplugging, then plugging in. (do not press "reset" button on router)
Feb 26, 2015 | Televison & Video
Can some one give me a free network pin code for my tmobile sony xperia z1s
Sorry. I think you are asking something what is not possible. Your phone does connect to the provider, with a sim card. it has an unique code and you can't copy it. Your provider does need this information, to bill your usage on the phone network. Without a Sim, no connection to the phone network, because no cell tower will connect you. (No service on the phone)
As soon as you want to work on WiFi, you need a WiFi router close to the phone. The maximum distance a WiFi router can be away is about 100 meters in open air. In a house or building it is much less.
To connect to such a wireless router, you need to have permission from the owner. Because he (most of the time) did setup the router with an identification name and a password. All connections you can see under settings and WiFi, are close to you. The ones you see with a little padlock are protected with a password. The ones without a padlock are open.
To access the internet yourself, you should have an internet connection in your house and a wireless router.
So I'm afraid without a sim or without an open WiFi connection to the internet, no soup for you. Pin codes won't work without any connection.
Sep 09, 2014 | Cell Phones
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
How to connect and use internet(wifi) by connecting samsung gt s5263 to laptop?
Absolutly not!
Wifi intenet connects to a ROUTER not a laptop.
1.You would need a Wifi router
2. You would need the WEP key from the router this can be done by clicking here.
Or
You could take it to a hotspot, most public plances offer FREE WIFI
I hope this helps.
Rulds2008
Aug 23, 2011 | Samsung Star GT-S5233 Cell Phone
I need help installing a bountiful wifi router to hugesnet internet_99_86@yahoo.com
Could you be more specific to the problem that you are experiencing?
Did you plug the hugesnet network side to the WAN port of your bountiful wifi router?
Are you able to get a DHCP IP address from the bountiful wifi router?
Are you able to get a WAN address from hugesnet?
Mar 01, 2011 | Computers & Internet
I am not able to understand how to use the wi-fi in my samsung corby pro mobile
you need to understand two things.
Wifi is a service which requires an access point i.e. a Access point hardware, also known as Wifi Router and A wifi enabled phone. As you hve mentioned that you have corby- pro, it does have a wifi chip to access the wifi signal. Now you must get a wifi access point, i.e. a Wifi router, d link has veriety of routers, Now connect the router with broadband internet line and enable it. Configure the router through your desktop.
Now switch on the wifi on the corby pro and establish connection between the wifi router and corby . Then only you will be able to connect with internet..
Dec 01, 2010 | Cell Phones
Deleted the Air Plus CFG.EXE cannot connect to internet anymore
If you still have the install disk for the router you can reinstall the router. Other wise you will need to go to dlinks website and download the driver to reinstall everything. Please rate
May 30, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Laptop won't connect to internet
Once connected to the ethernet cable you might have to press the tiny reset button on the back of either your gateway,router,modem of whichever service you have(Cable,DSL)
May 27, 2009 | Dell Latitude C400 Notebook
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
D-Link DIR601 WirelessN 150 Home Router and DLink DWA125 Wireless 150 USB Adapter Bundle Logo
105 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
