Question about Acer (54.AA806.001) Sound Card
No sound everything else appears to be fine .help .thank you speakers are on plugged in correctly .would it be a sound card problem ?
  • 1 more comment
  • steffysieler Jan 16, 2009
    thanks everyone but still no progress
  • Anonymous Jan 17, 2009
    I have the same problem - but dum me mistakenly uninstalled my RealTek97 sound driver and I'm trying to get it back. I might need some help here.
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Have you installed your audio driver?
  • 238 Answers
You have to insert it into the right port. If all of the ports have been tested and audio driver was installed already and have checked whether it is not in a mute mode, then your sound card is defective.
Posted on Jan 16, 2009
  • 43 Answers
Do like this Push Start>>>controlpannel>>>unitmanager.. If you can see A High lighter Yellow text with you audio cards name dubble click on it. if it's all gray taged you need to Install it. or Now it shall work
If not Search after driver to your audio card internet witgh your audio card model number...
Posted on Jan 12, 2009
I spilled tea (unsweet thank goodness, no
It could be the poblem with your speaker change it and also check the cable
thanks
May 14, 2010 | Computers & Internet
No sound even though the computer says everything is working fine, it's not muted, under device manager everything shows to be working. Help Thanks czanfardino@aol.com
Are the speakers plugged into the correct jack (audio out, not line in)? Check if the speaker cable is damaged and try replacing it if the wire is not fixed. If the speakers are self-powered, check if the transformer is warm (using power). If it is cold, look to see if the specs are given - you may be able to find a universal power supply with the right voltage and amperage at a shop like Radio Shack.
If the speaker wire is fixed, you may be able to open up the speakers and desolder the wire and solder in a new one. However, on low-end speakers, the fix is takes more time than the speakers are worth.
I hope this helps.
Apr 24, 2010 | HP Compaq Presario S3100nx (DC477A#ABA) PC...
My acer inspire desktop doesn't appear to have any sound. Should it have integral speakers? I have a small set of speakers plugged into the headphone socket on front panel, but nothing. Have tried it...
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers2_bing.gif Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues. "In the See also: (Category), click, on “Audio Devices2_bing.gif, and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced), “not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers2_bing.gif. Check to see if Device usage: (enable) if not? "Change it." *Note: “Click the "OK" to all change; 'Save,' and apply!” before exiting. “Did this solution help?” Feedback: “Helpful Ratings” appreciated! Thanks, paul7of9”
Feb 15, 2010 | Acer (54.AA806.001) Sound Card
No sound on the Vista comupter. speakers plugged
Dose the sound card have surround sound on it, might need to enable the surround on it. Or try to plug the speaker cable in the black or green hole. And see if that matters. Good luck!!
Oct 03, 2009 | Creative Labs SoundBlaster Live! Sound...
Creative Inspire T6100 5.1 - No Power
Turn the volume on the right speaker up?
Sep 27, 2008 | Audio Players & Recorders
No sound from p5k3 motherboard
have you connected to the motherboard with correct plug(generally green in for audio out)try with another of speaker if the problem persists than you onboard sound card is having problem
May 15, 2008 | ASUS Computers & Internet
No Sound
carefully plug back the minijack for the speaker at the out or spk,
normally the sound card has three ports 1. for MIC 2. LINE IN 3.OUT (SPK) - SPEAKER.
carefully plug the minijack for the speaker into the third one - OUT (SPK) - SPEAKER.
in pluging it in, first put on a media clip on the windows media player and carefully plug in the minijack for the speaker and surely you will hear sound.
UZOWUANYA
e-mail: uzowuanya@yahoo.ca
Feb 11, 2008 | Dell Dimension 3000 PC Desktop
Logitech R-10 speakers
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Mar 07, 2007 | Logitech R-10 Computer Speakers
Computers & Internet Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
