Question about Watches
Prologue Model YRO4238/02. Removing back for battery change. Ends of watch band are in the way.
The edges of the watch back extend underneath the inner ends of the watch band, and I need to know the proper way to move these ends of the band out of the way.
  • 1 more comment
  • George R. Swieringa Dec 07, 2012
    After some experimenting I solved the problem myself. The ends of the spring loaded pins can be seen from holes in the end of the bracket that is holding down the band. The are less than a millimeter in diameter so you need to use something like a small nail with the point filed off to depress the pin and lift off the bracket. A third hand is very helpful for this. The pins are the same as those used in most watch bands, but are not visible because of the way the band is designed.
    George R. Swieringa Dec 07, 2012 After some experimenting I solved the problem myself. The ends of the spring loaded pins can be seen from holes in the end of the bracket that is holding down the band. The are less than a millimeter in diameter so you need to use something like a small nail with the point filed off to depress the pin and lift off the bracket. A third hand is very helpful for this. The pins are the same as those used in most watch bands, but are not visible because of the way the band is designed.
    Sorry about the duplicate message, but I'm not real familiar with how the FixYa site works. I simply wanted to add a "y" to the sentence "They are less than a millimeter"
3 Suggested Answers
SOURCE: removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Posted on Apr 23, 2009
escapement
  • 2334 Answers
SOURCE: Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Posted on Apr 08, 2010
Does this leather band come out someway ? I can not see any pin holes ? My Husbands wants to switch it out to a buckle clasp instead. Is this possibile with watch ?
yes
under the band at the ends there is a small spring loaded pin that is removed and the band comes out
use something with a sharp edge , press in in beside the leather and then push sideways to compress the spring and the pin will come out
or take it to a jeweller and he will remove and fit the new band in 5 minutes
Feb 16, 2017 | Watches
How can i take the back off the invicta sea spider model no. 5915 so i can change the battery?
Hi I love my Invicta watches also. My wife is telling me that collection is close to how many shoes she has LOL. You will need a special tool the tool has two adjustable prongs so it will fit a Rolex and any other screw on type watch. Normally they come in a set of watch tools. I would suggest eBay, you can get a kit that not only will open any back on any watch but you will get tools for removing the pins in the band. There is also a unique tool to help you put the spring pin in that holds the band to the watch. One word of caution when searching on eBay look to see where the seller is. If it is China I would find one here in the States. I hope this will help you
Have a great day.
MgySgt Shirel USMC (retired)
Apr 21, 2016 | Invicta Watches
How do I change batteries on a M.Z. Berger AW 213 watch
I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
Apr 28, 2014 | Bulova Watch
I need to change the battery of my watch and i don't find the place for removing the back cover
some watches have a notch that comes out where you can get a knife, or exacto blade underneath to pop it open. if not, there may be multiple intends along the ridge that would require a special tool to twist open. any jewler could change the battery for you. also, batteries plus stores can change the battery out at a reasonable price.
Aug 15, 2011 | Callaway CY2058 Sport Series Watch
How iI open a casio 705 woman watch?
Thank you for contacting FixYa.
You will need:
  • A jeweler's screwdriver- Either flat head or Philips, depending on the model of watch.
    A cup or small box-This is to hold any screws.
  • How to change a Casio watch battery:
    1. Spread a cloth over your work area The cloth will help you avoid damaging the finish on your watch.
    2. If necessary, remove the watch band Removing the band gives you easier access to the back plate.
    3. Remove the back plate For some models this means using a screwdriver to gently pry it open, and others require removing screws. Keep small screws in a container to avoid losing them!
    4. Take note of the rubber seal Sometimes they need to be reinstalled in the same orientation. You might even want to use a marker to make a small "match mark" before removing it.
    5. Locate the battery It looks like a small metal button.
    6. Remove the battery You might need to loosen (not remove) a small screw and slide a latch out of the way. For other models, it's as simple as popping open a strap that is stretched across the cell.
    7. Install the new battery Make sure it's in the same orientation as the old one. They usually go in with the positive (+) side down.
    8. Perform a reset Do this by touching one tip of the tweezers to the AC contact, inside the watch, and the other tip to the back of the watch battery.
    9. Make sure the watch is working properly Carefully lift the watch to do this. Don't turn it over or the watch movement might fall out.
    10. Reassemble and seal the watch Perform steps one through four in reverse order to reassemble your watch.
    Best regards. Jewel
    Sep 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    How to shorten watchband
    It all depends on the style of the band.
    Go to where the links are all the same size, not tapered at all.
    If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
    If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
    Dec 28, 2009 | Seiko Watches
    Removing the back to change battery
    Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
    I cant open my brand new watch ...HELPPPPPPPPPPPPPPP!
    I just recieved a Moldavo Men's Junior Sport (Model # 0605105 with certificate of authenticity) as an award -- but the instructions didn't bother explaining how to put the watch on!
    For any hidden clasp band, see this web page (excerpt below):
    http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
    Refer to the "Hidden Clasp" diagram and follow the instructions under the diagram:
    cad9c3e.jpg To open this clasp, reach under the bracelet band and lift upwards. The band extends to allow for easy removal.
    Jan 09, 2008 | Movado Kardelo 0605479 Wrist Watch
    Watches Logo
    115 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
