Question about Whirlpool Washing Machines
Sound from drier of WHIRLPOOL ACC 75I - Whirlpool Washing Machines
How do I fix my drier when all it does is beep three times when I push the start button but will not start?
Try to look if the cable is unplug or something is placed wrong or if it might be a mouse that is biting the wire .thanks for my opinion.
Jan 10, 2015 | Whirlpool Dryers
Whirlpool twin thin lt5000xm
check your fuse/breaker panel, for a double breaker for the drier, switch it off and back on to reset it, and see if that fixes it.. very strange that both devices would be affected. sounds like somebody wired the washer outlet to the drier circuit. VERY UNSAFE.
Mar 11, 2014 | Dryers
Drier won't heat
try replacing hearter wire under drier
Apr 08, 2012 | Whirlpool Dryers
What direction is the flow on a Whirlpool refrigerent drier?
Good day,
Flows from the tail end of the condenser into the dryer, out of the dryer into the capillary tube.
Dec 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The dryer heats up but drum will not spin
It sounds like the drier belt eg: drum belt. (Disconnect power) then raise the top on the drier it has hinges on the back and spring locks on the front, take a putty knife or butter knife and slide it in the crack untill you find the hinge push in on the lock and lift, there should be two of them. You will then be able to see and have access to the belt.
May 31, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Noise from rear of Machine Sounds like metal rubbing against metal
on the whirlpool driers there are two support rollers that need to be replaced periodicly. the best thing to do is to get a repair kit or tune up kit. it comes with a new set of support rollers, an idler pulley and a new belt. If you are confident it is a fairly straight forward repair. ***ALWAYS UNPLUG THE DRIER BEFORE YOU DO ANY THING***
Nov 07, 2008 | Dryers
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal De
