Question about Dishwashers
Frigidaire dishwasher model FPHD2491KF0. The motor and capacitor is good but will not start what is the problem?
I have put a pig tail to the motor and it runs, I have put an OHM meter to the capacitor and it is good I just need to know why the motor is not engaging. the dishwaser will run the water and drain through the cycle like it should but the motor will not engage to wash the dishes.
5 Suggested Answers
  • 1314 Answers
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Posted on Jan 17, 2008
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
  • 24 Answers
SOURCE: I have frigidaire dishwasher,starts cycle,can hear
Depending on your dishwasher, it fills either by a timer or by a water probe or float. I will assume its a timer as a probe or float wouldnt exhibit this behaviour. I would say you have a restriction in your water supply line. Check your valves, any screen filter in the water line for sand/scale/silicate/etc, pressure regulator if applicable. Another posibility is a poor magnet in your fill valve.
Posted on Dec 19, 2009
heatman101
  • 43501 Answers
SOURCE: frigidaire built in dishwasher model PLD2855RFC1.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 04, 2011
How can I get my Frigidaire Dishwasher 900 series to start?
Sounds like you have a bad door switch. You might also have a motor that tends to freeze or lock up. It could possibly be a bad motor capacitor too. Does this help?
Mar 18, 2015 | Frigidaire Gallery Dishwashers
Tip
We recently installed a new dryer and everything worked but it did not heat. We...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on May 02, 2009 | Kenmore 62602 Electric Dryer
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Someone cut off cord.Iwant to wire on new cord in proper place
If you remove the bottom panel of the dishwasher below the door right at the floor you will see on the right hand side, a metal box with a philips head screw holding the side of the box dowm. If you remove this screw you will see the electrical connections that you can wire this pig tail to properly
Good luck hope this helped you some
Dave
Feb 19, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Stopped working no power light come on like it's dead.The power supply is fine to the plug and the fuse is ok it just stopped why? is there a reset button anywhere?what would cause this? no hint of a...
check where the pig tail the plug going into the wall follow the plug wire to the connection at the dishwasher. You will need to remove the bottom panel of the dishwasher at the floor. This access panel allows you to see the underneath of the dishwasher. Where the plug wire (pig tail) connects to the dishwasher it is in a small square box on either the right side or left at the front of the dishwasher. Unplug your washer and remove the cover off of this box and check to see if the connections are indeed connected.
Hope this helped
Dave
Feb 17, 2010 | Dishwashers
I am not getting any power to my dishwasher? Checked the breaker, the outlets. all good there
you need to take the very bottom panel off the dishwasher. This panel is located at the floor and is held on with 2 philips head screws once the panel is removed look for an electrical plug located under the dishwasher(use a flashlight for the best look) What you are looking for is a "pig Tail" which is a small section of what looks like an extension cord which should run into a small metal box (make sure your breaker is off before going any further) Now remove the screw holding the flap to this metal box and look to see if the cord is connected to the proper power feed to the dishwasher, should be wire nuts on the ends of the wires. untwist the wire nuts and make sure the wires are properly twisted together black to one wire off the pig tail and white to the other side. Follow the wiring back to the plug to insure that the end of the pig tail is plugged in. That should cure your problem if you are getting power to this metal box then the problem is internal in the dishwasher itself.
Hope this helped
Dr Berry
Feb 16, 2010 | Dishwashers
'97 Ford Expedition has short in tail light pig tail
queens english please, whats are you calling a pigs tail ???never heard of this before after 40yrs in motor repairs
Dec 29, 2008 | 1997 Ford Expedition
Frigidaire - model - FWS747RFS1
I'm having the same problem with a Frigidaire Crown Washer.
It is the start capacitor which is out on mine.
This is how I confirmed that:
Be careful with your fingers and turn on your washing machine, unplug it, and remove the belt from the motor. Plug the washing machine back in and turn it on. When it gets to a spin cycle, turn the washing machine motor by hand (WATCH YOUR FINGERS!!) and if it starts spinning on its own, then your motor is good and it is likely the start capacitor.
For further testing of the start capacitor, go here:
http://www.wikihow.com/Check-a-Start-Capacitor
My start capacitor has a resistance of 1 ohms and never makes it all the way to 0 on my multi-meter when doing a resistance test.
Oct 15, 2008 | Frigidaire FWSB5700DS Top Load Washer
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
Owen Barnes
