Question about Bosch Nexxt 300 Series WFMC2201UC
Is there a reset button on a bosch 300 series washing machine
It doesnt want to wash it just keeps saying error on it i clean all the drains and no luck!
  • 441 Answers
Turn off the power to the unit for 45 min, that resets it
Posted on Dec 06, 2012
  • JUAN SARABIA
    JUAN SARABIA Dec 08, 2012
    well it work now the band keeps falling i dnk y
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
richroth
  • 9472 Answers
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Posted on Nov 26, 2010
My Bosch Vision 300 series washing machine wont start?Why? What has to be done to it?
Michael, the door lock/latch mechanism should be tested, if faulty replace. Have a good repair Tech. check, diagnose and estimate repair. Make sure to at least look at the first link, it tells of a reset procedure that may fix your washers door latch problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://baubilt.com/?p=1318
How to replace washing machine door lock on Balay Bosch Neff and Siemens
http://www.repairclinic.com/Shop-For-Parts/a11b129/Bosch-Washing-Machine-Parts
Aug 22, 2016 | Bosch Washing Machines
Reset botton on bosch dryer keeps poppig
this machine is like you it needs to breath like you?
if filter not clean the themostats kick out
so clean the filter and air ways
Jul 15, 2014 | Bosch Nexxt 300 Series WFMC2201UC
E04 error code, washer wont drain, water left in tub on a Bosch Nexxt 300 series
http://applianceguru.com/attachment.php?id=2463
Make sure you click helped, if helped that is.
Apr 12, 2013 | Bosch Washing Machines
My Bosch 300 series clothes washing machine is leaking alot. It leaks during the initial wash cycle from the lower left side. I have cleaned the detergent tray and it appears fine. I have also opened up...
Bosch 300 series This video will show you the 5 main areas to look, the washing machine door seal, the pump, check the drum bearings; look for a split hose, water coming out of the soap draw. This video tutorial will help you find the leaking parts and will also show you what needs to be done to repair it
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 26, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a bosch 300 series front load washer that wont spine it fills and drains fine belt is on what could it be
If it doesnt wash either, the brushes will possibly be the problem. You need to remove them and check the length.
Aug 04, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 Series WFMC2201UC Logo
1,161 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
