Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
How to enable diagnostic mode - Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
    Top Expert:
  • Electrolux Master
  • 9,472 Answers
Look for the tech sheet under the top of the unit.
Posted on Dec 06, 2012
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
My laptop does'nt work in normal mode but its working on safemode.thus anybody can help me how to enable a sound on safemode? thanks in advance for those who have idea
"Safe mode" is really a diagnostic mode. "doesn't work" means what? Depending on what the problem is, we may be able to fix it. Please describe exactly what you mean by "doesn't work". Screen blank? Keyboard not responsive?
You can try setting the screen resolution to 640 by 480 while in safe mode, and see if that gets you someplace when you go into normal mode.
Oct 13, 2014 | Toshiba Satellite L305-S5939...
520230. 31520193. 7Polaris 550 Xp eps 2009About 20 hours on unitStored indoorsI understand one code is Idle air and the other is power steering is disabled or not functioning. First I would try and...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
screens.
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
46 FEATURES
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Jun 28, 2013 | Polaris 2009 Sportsman 550 EFI XP With EPS
How do i reset code e63
your coils in the heating unit are touching the can you will need to clear them probably have to replace a broken porcelin insulator once you do this then you can reset the machine.
factory reset, press and hold the temperature and dry level buttons simultaneously for 6 seconds for models with temperature and dry level and dry time buttons press and hold the drylevel and dry time buttons simultaneously for 6 seconds.
diagnostic mode press the cancel button to enter standby mode and enable diagnostic entry.within 10 seconds after pressing cancel press and button but cancel to wake up the control. within 5 seconds of wake up turnthe selector knob to the far left cycle and press and hold the cancel and the center button under the display simultaneously for 3 seconds to enter the diagnostic mode. upon entering diagnostic mode all lights should flash on and off turn the selector knob clock wise on setting, you will need a book inside the dryer to read the codes pop off the top of the dryer it should be folded down in the front of the machine...
Jul 29, 2012 | Electrolux EIED55H Dryer
Remote starting diagnostics says "Manual
A tach MUST be connected for manual transmission installation. Start there.
Jul 01, 2011 | 5301 Responder LE 2Way Remote Start and...
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clio sport wont rev over 3500 rpm
It's in protection mode.
There's a fault somewhere which will harm the engine and so the engine defaults to a setting which will enable you to drive to the nearest Renault dealer or any other repair garage with a comprehensive diagnostic computer. Note that many independent garages have cut-price, cut-featured and frequently out of date diagnostic computers and vehicle data discs. It's one of a very few occasions that I'd actually advocate going to a main dealer.
Mar 13, 2010 | Renault Sport Cars & Trucks
How do i get safemode in full screen or full resolution so there is not black borders around the out side
When you power up the computer Press and hold F8 key 5 to 6 times untill you see windows logo then you can see safe mode and other menu enter in enable vga mode then go to start menu->control panel->display ->property ->settings .
change screen resolution to 1024*768 then apply and ok.
Then check .
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 07, 2010 | Computers & Internet
Will not boot to Safe Mode
Try to boot from the Resource CD by selecting the <F12> key and select boot from CD/DVD drive. If you tried to run the "Diagnostics" option from the <F12> boot menu and it went to command prompt, there might be an issue with your hard drive or the "Diagnostics" partition is corrupted or missing. If all tests pass using the Resource CD, then your OS is probably hosed. As for the 9 LED light, that just indicates that your numeric keypad is enabled.
Oct 17, 2008 | Dell Latitude D510 Notebook
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
256 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
