Question about Dell 7330dn Laser Printer
DELL 7330 ERROR E3-6
SHOWING THIS ERROR AND IT MEANS THERE IS A PAPER JAM. FOLLOWED ITS INSTRUCTIONS AND CANT SEE ANYTHING!
flopez
  • 161 Answers
SOURCE: Dell 1600 paper jam 1 or no cartridge
Your unit is actually manufactured by Samsung. Most probably you have a bad paper sensor. As a technician, you will find these sensors on the power supply board (SMPS)or main board. If your are receiving tech support from Dell, please illustrate those guys on how to do their job.
Posted on Oct 02, 2007
SOURCE: Paper Jam error
If it works like the 1700n (I think it does), if you press Continue twice it should light up different lights as a secondary error code. It should tell you close to where it thinks the paper jam is. Check the sensors there, clean them, whatever. If you have a spare printer, or another one, you may try switching out the sensor (takes some tearing apart of the printer) and see if that fixes it.
Posted on Jul 17, 2008
  • 5 Answers
SOURCE: Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
NitrusInc
  • 326 Answers
SOURCE: I have a Dell W5300 printer. After removing all
Have you attempted leaving the printer unplugged (if possible in the on position) for a period of 5-10 Minutes?
Posted on Apr 13, 2009
devdeep545
  • 137 Answers
SOURCE: Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Posted on Aug 09, 2009
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
My dell printer shows error after I have cleared the paper jam.
Try and check the ink or maybe the paper is scrunched up smooth them out.. If this doesnt work then sorry this all i can do XD
Apr 04, 2013 | Dell 1250c Color LED Laser-Class Printer...
Error 3 is showing it also says swith off and on
this error mean : paper jam (location) it mean a non specific paper jam occored
follow this step to fix:
1. remove jammed media fro the specified location
2. verify the paper tray is fully closed
3. inspect and/or replace the feed and separation roller
4. ensure there is no obstruction on the path, such as a torn piece of paper
5. open and close the top cover to clear the messaage
6. check sensors andflags for proper operation
i hope this helpful
thanks for using fixya
Jan 28, 2011 | HP LaserJet 3055 All-In-One Printer
I have a dell 948 all in one printer, clear paper jam then press check. There is no paper jam. I have follow instruction and site recommendation, ran printer software, problem still exist, please help
This is a known issue with Dell all in ones.
It's a problem with the power supply inside the unit.
If you were in the middle of a print job, though, and it jammed, do recheck as I've been caught out
with a paper jam where a tiny partical of paper was doing the jam. Look carefully before contacting Dell support.
Dec 31, 2010 | Dell 948 All-In-One InkJet Printer
Dell 922 saying there is a paper jam
First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
Good luck.
Thanks for using FixYa.
Jul 16, 2010 | Dell 922 All-In-One InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Dell1600n showing a document jam, have tried everything eg switching it off but cant find a solution. it prints fine and copies fine as well just isnt taking anything from the ADF. So I cant send a fax...
check the gears in the adf maybe you have one that is misaligned ,run a piece of paper following the paper path check the flag sensor make sure none of them is jammed close or misaligned.
Good luck
Jul 09, 2009 | Dell 5310n Laser Printer
Dell 3010cn paper jam 075-134
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 12, 2008 | Dell 3010cn Laser Printer
Canon mp145 error 3
it means that there is something still trapped inside. a piece of paper maybe or anything. are you sure you already remove the whole piece of the paper or not?
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error message
Hi, As you are facing the paper jam issue please follow the instructions in the HP weblink : Here is the weblink that address your issue: ========== http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=390315&lang=en&docname=c00265823 ========= Just click on the link and follow the instructions to fix this You can also try to reset the printer to factory default if this dose'nt work Wish you success Regards, Barret.
Sep 27, 2007 | HP PSC 1610 All-In-One InkJet Printer
Dell 7330dn Laser Printer Logo
174 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
