Question about Frigidaire Affinity ATF7000E Front Load Washer
Door lock doesnt lock - Frigidaire Affinity ATF7000E Front Load Washer
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
The lock is faulty and needs to be replaced. Here is the lock to order.
Here is a video to show you how to make the repair.
Posted on Dec 06, 2012
Interior driver side door handle does not open the door and doesnt lock.
remove interior door card and inspect door handle rod to lock mechanism make sure it is connected both ends
Oct 06, 2015 | Cars & Trucks
Driver door lock will not lock with key entry or key pad
press the last two keys on your outside door keypad simultaneously, all doors should lock. if this doesnt work suspect the doorlock actuator inside the door panel
Apr 08, 2013 | 2007 Lincoln MKZ
92 Honda Accord EX Wagon doors not locking
If it was the actuator in the drivers door the other doors would still lock. this sounds like a bad connection, test the drivers door switch, the other thing is do the doors lock if you use the pass/door switch to lock the doors? if it doesnt then its not the switch but if it does lock the doors then replace driver door lock switch. if the switch on pass door doesnt work to lock then check wiring. look at wiring going into driver door, look at the door, open it, look at door hinge area and in the middle you will see the rubber boot that holds the wiring for that door. remove the boot or rather slide it back and check for any broken wires. its common for wires to break from opening and closing the door. good day.
Oct 20, 2011 | 1992 Honda Accord
I have a 2003 Lexus GS300. My passenger side door automatic lock doesnt work. It flickers back and forth when I use my key and button on the drivers door but doesnt fully lock or unlock. What could be the...
A seized up door lock actuator. You can try freeing it up by spraying a good penetrating oil, my favorite is PB Blaster. If it wont free up you will need to replace it.
Jan 24, 2011 | 2003 Lexus Gs 300
My washing machine door doesnt lock properly
its most likely your door lock if it is malfunctioning the washer will not work
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Automatic power lock on driver side sliding door doesnt unlock
sounds as if the linkage has come undone remove the door panel and inspect if so simply insert back into the hole it should line up to the lock and insert it a plastic clip will lock it back onto the rod if not present it may be at the bottom of the door if you cant locate it a parts store will carry them .reverse procedure to reinstall door panel
Sep 12, 2009 | 2003 Chrysler Town & Country
Alarm and door lock malfunction 1996 Camaro z28 LT1
Hey just wondering if you ever go this problem fixed. I am having the exact same issue. Thanks
Jul 03, 2009 | 1996 Chevrolet Camaro
Cant open rear doors from the inside; cruise control doesnt work
after cking the child lock, try locking and unlocking the manual locks to see if you can hear any movement inside the doors. if all else fails, you have to remove the door panels.. starting from the aft lower corner, (careful not to tear the plastic moisture sheeting, just peel it back), the door panels are normally held in by plastic plugs and screws under the armrest, etc. once inside the door cavity, ck the linkages for wear or any signs of them being disconnected. try all the lock mechanisms again to pinpoint the cause, its good practice to clear all the drain holes at the lower part of the cavity once you're in there.
Jun 02, 2009 | 1996 Audi A4
The power door lock doesnt work!
It sounds like a bad lock actuator. this is the devise that trips the lock. It's found in the door panel.
Jan 30, 2009 | 2001 Audi TT
Keyfob lights up but central locking doesnt work
try looking in the door and see if the bar to central door lock mechanism hasnt come off where the little plastic clip has broke that retains it
Nov 02, 2008 | 2000 Renault 181
Frigidaire Affinity ATF7000E Front Load Washer Logo
337 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
