Question about Dodge Vehicle Parts & Accessories
2005 dodge stratus front wheel. Stripped lugnut cant get tire off.
Took it to various tire places no one can get it off.
  • timothy j mckenzie Dec 07, 2012
    just one lugnut is stripped, nothing i do can get it off. i have taken it to no less than 3 tire experts. need help to try to get off.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 74 Answers
2005 dodge stratus front wheel. Stripped lugnut ca - 2q==Get one of these lug nut removal tools. Do not get a cheap one, get one that is strong enough to slightly cut the lug nut and bite down into the metal. Start working it with a breaker bar and a hammer to get an initial bite. switch to an impact wrench and take it off. WD-40 or some other penetrating oil will help a bit, but make sure the lug nut surface itself is not dripping (the tool you just got will slip off of it).
The other method is to use a rotary tool and carefully begin to cut the lug nut metal. Be careful not to gouge the lug itself, or you'll have to replace that too (done it myself).
Posted on Feb 06, 2014
Front drivers side tire is flat, and I can't remome it??
THERE IS JUST BUILD UP IN THE LUG HOLES. TURN WHEEL ALLTHE WAY RIGHT HIT THE INSIDE OF RIM WITH HAMMER AS YOU TURN THE TIRE & WHEEL TO DIFFERENT POSTIONS.
Jan 27, 2011 | 2001 Dodge Neon
How to install outer tie rod on 2005 dodge stratus
unbolt it, andr eplace it. get it as close to the same spot as the old one, then have the toe on the front wheels reset (wheel alignment)
Nov 22, 2010 | 2005 Dodge Stratus
I took the lugnuts off of the tire on the 1999 mercury cougar i bought but still cant get the tire off. Any reason why?
ist rusted onto the hub. you can try kicking it with your foot or putting the lug nuts on loose and then roll the car slowly until the wheel comes off. At the shop we all have large plastic dead-blow hammers just for whacking wheels off of cars!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 26, 2010 | 1999 Mercury Cougar
How do i change the battery in a 2005 dodge stratus
You need to remove the left front tire. Remove the plastic keepers on the panel that you see there inside the wheel well, the battery is behind that panel, disconnect the negative post cable 1st then the positive and then the retainer block and slide the battery straight out and back
Jun 04, 2010 | 2005 Dodge Stratus
Should there be a snap ring holding rotors in place on a 1999 dodge stratus?I get front end shaking at certain speeds.
Have the front end checked by a mechanic. The problem could be wheel balancing, front end alignment, broken tire belt or a number of related things. The rotors are held in place by the wheel lug nuts. Good luck!
Nov 29, 2009 | 1999 Dodge Stratus
2005 DODGE STRATUS HOW TO REPLACE THE BATTERY
REMOVAL
The battery is accessible without removing the left front wheel and tire assembly..
Verify that the ignition switch and all accessories are OFF.
Turn the steering wheel to the full left position.
Disconnect and isolate the negative battery cable remote terminal from the remote battery post.
WARNING: NEVER GET UNDER A LIFTED VEHICLE IF NOT SUPPORTED PROPERLY ON SAFETY STANDS.
Remove battery splash shield. Refer to the Body section of the service manual for the procedure.
Disconnect the heater blanket cord, if equipped.
Remove the short bolt from the battery hold down and remove the hold down (Battery Location).
Disconnect the negative and positive battery cables from the battery.
Slide the battery toward rear of vehicle and lift out of the battery tray.
Remove battery from vehicle.
Oct 18, 2009 | 2005 Dodge Stratus
Whining noise from front end while driving
you have a bad front wheel bearing..jack up front of vehicle..put in neutral..block rear wheels..put 1 hand on front coil spring and rotate wheel..you will feel roughness in spring on side that wheel bearing is bad
Jun 14, 2009 | 2004 Dodge Stratus
I have dodge stratus 2001 and I need to change the battery i couldn't find where it is
Front driver's side, black plastic panel towards the front of the driver's side fender. Jack the car and take the wheel off. There are 5 fastners that are there that need to be rotated counter-clockwise a quarter turn. Wiggle that panel out....there's the battery. A bracket keeps it in place, one bolt, one nut. Remove that and the battery slides right out. It is easier to remove it by taking off the tire but you CAN remove the battery with the wheel on. Just turn the wheels all the way to the right, like a hard right hand turn.
Nov 27, 2008 | 2004 Dodge Stratus
MY CAR HELP
It sounds like you also will need a wheel bearing on that same wheel. ... Thanks Dan
Jul 10, 2008 | 2005 Dodge Stratus
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
