Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water line keeps freezing on my GE side by side refigerator
It's a 5 year old GSH22JFXM unit. Has worked fine until recently when the water dispenser stopped dispensing water. Ice still works fine. Repair person came out and replaced the water valve in the back of the fridge because it had low pressure. He had me unplug fridge for about 12 hours to thaw the line. That worked and I ran seveal quarts of water through the line but it froze again later in the day. He returned to check the valve which is fine. I know the freezing line is a known problem with GE side-by-sides. There doesn't seem to be any satisfactory fix except to replace the whole fridge..... can you tell me anything different?
  • 9 more comments
  • D.J. LONON Dec 07, 2012
    The repair person checked the water tank and it is not frozen. He replaced the water valve which didn't fix the problem of the freezing water line. After unplugging the freezer overnight, the line thawed and I'm trying to prevent freezing by running water thru the line whenever I'm in the kitchen. There doesn't seem to be a real fix for the freezing line without spending a lot of money.
  • Richard Roth
    Richard Roth Dec 07, 2012
    Is anything freezing in the refrigerator section?
    No.
  • Richard Roth
    Then the freezer is to cold and freezing the line at the door. Try turning the freezer temp down some.
    Yes, that's the conclusion I've come to. I have it on the lowest setting (1). It froze before set at that number, so we'll see what happens. I might have to buy another unit - definitely NOT GE however!
    I really appreciate your input, thanks.
  • Richard Roth
    Let me ask you this, is everything really frozen solid in the freezer even on the lowest setting?
    yes
  • Richard Roth
    Ok, that's what I thought. Replace the temperature sensor in the freezer and that should do the trick. Here is that part to order.http://bit.ly/UjzRpi
  • D.J. LONON Dec 08, 2012
    Thank you Richard. Is it an easy part to install?
  • Richard Roth
    Richard Roth Dec 08, 2012
    Yes, you will need to pull the shelves and then the rear panel to get to the coils in the freezer and you will see the sensor.
    Top Expert:
  • GE Master
  • 9,472 Answers
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Posted on Dec 05, 2012
dididsaythat
  • 291 Answers
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Posted on Aug 21, 2007
rpbuice
  • 161 Answers
SOURCE: ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Posted on Jan 19, 2009
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
SOURCE: Water Dispenser not working
If the ice maker is working, and no water is coming out, the water line may be frozen.  This happened to me yesterday, and I followed the advice on ehow.com.  It worked like a charm! Take a hair dryer, and blow hot air up into the dispenser tube, holding the hair dryer about 8-10 inches away.  After about 5 minutes or so, a tiny chip of ice and a couple of drops may pop out.  Fill up a couple of glasses of water to flush it out, and you should be good!
Posted on Sep 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Posted on Nov 25, 2009
We have a GE profile side by side refrigerator with the freezer on the bottom (model PFSS6PKW). It's not quite 4 years old yet, but we've been having issues with low water pressure from the water...
you may have a restriction in the water line ( after the valve and it may be in the water storage tank .. it may be ice and it will block the line some what . to slow the flow .. if not ice it may be sediment / these are the most common found .. .. i would clean the lines or replace them .. . if pressure is ok at the main inlet line .. ..mm hope this helps mm
Jul 11, 2011 | GE Refrigerators
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Refriderator about 3 years old. Recently the water dispenser stopped working, and the ice maker stopped as well. The ice maker seems to freeze up as it dispenses water in the tray to make ice....
Are you having any cooling problems whatsoever, anywhere? Is there any area in the unit that you dont put food for cooling reasons? if cooling is fine, check the water pressure as it comes into the refrigerator, you wil have to disconnect the water line at the solenoid valve behind the fridge. If pressure is good, pour 4-8 oz of water into ice maker, does it eject those cubes within 24 hours? then replace your water valve(s) One assembly houses a solenoid for both the ice maker and the water dispenser, both solenoids are bad.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gsl25jfrfbs water disoenser not working
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice forming on condenser copper tubing GE referigerator
is your drain line plugged up under that coil? another thing to check is if the door asket pinched that wold allow ait to infiltrate into the freeze and freeze up the coil. remember to clean under the unit once a year to keep the unit working properly and not having to struggle to condense the refrigerant. Hopt this solution's work for you and have a Happy New Year.
Jan 05, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
157 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
