Question about Canon PowerShot S1 IS Digital Camera
Error message E18
When I turn the camera on the power light flashes the LCD screen stays black, then it beeps an the error code E18 comes up on the LCD screen.
  • Canon Master
  • 4,738 Answers
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 12, 2009
Camera does not power on. I get three beeps,
Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 22, 2009 | Canon PowerShot S2 IS Digital Camera
The screen won't come on for viewing and the lens won't retrack, it also started popping up with E18
That is shutter error code. I am sorry to tell you have to buy a new camera, it would be to expensive to replace.
Nov 15, 2009 | Canon PowerShot A95 Digital Camera
Not turning on, light blinks once that's it
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
May 29, 2009 | Polaroid I533P Digital Camera
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
Canon pwershot s1 IS E18 error code
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 14, 2008 | Canon PowerShot S1 IS Digital Camera
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
Blank screen - I don't think it's E18
Try and clean the LCD connector _flexible connectors. If you are able to see the dark picture- The back light panel is defective or improper contact. If the picture is perfect in the PC when you download,,then the LCD may be defective For LCD pl.e mail me...may be we can give a new one.
Dec 02, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
132 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
