Question about Dell Latitude E5410 Notebook
Why does my laptop shutdown when I close it?
The laptop suts down when the lid is closed
    Problem Solver:
  • 13 Answers
You can set it so it just sleeps until you lift the lid agen you need to go into your computer settings not to sure which setting it is as most computers are differnt hope this helps
Posted on Dec 05, 2012
This is a feature of Windows Laptops, It attempts to save energy or assumes you no longer need it turned on.
You can change this setting by typing "Power Options" or "Power settings" into the Search bar in the start menu
tleeski
  • 29 Answers
SOURCE: D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Posted on Feb 12, 2009
freetek
  • 5568 Answers
SOURCE: The computer ignores the Power
The Windows power management function seems to be very particular as to the system in which is is installed; I have seen similar uncorrectable glitches on a variety of systems and while the 'Hibernate' worked fine on our system for an extended time, it has since stopped working and refuses to come out of hibernation now. Frankly, it seems just one more of those annoying MicroSoft 'things.'
Posted on Oct 24, 2009
  • 3940 Answers
SOURCE: While at home I plug a wide screen monitor into my
You appear to be cloning your internal LCD and as long as it is active, the resolution setting for the LCD is also controlling the resolution of the external monitor. When the LCD is closed, then the default resolution of the external monitor is being used by Windows 7 (It apparently has autodetected the size of the monitor and knows the Highest optimal resolution it will display.) The higher the resolution, then smaller the icons.
To resolve, go to display properties and check the resolution of the internal LCD and then set the External display to the lower resolution.
You should be able to wake the system with an external keyboard, by pressing the spacebar, if the system is sleeping
Posted on Jul 25, 2010
Testimonial: "Thanks, my LCD Problem is fixed. I have an external keyboard and mouse connected by USB but neither one will wake the computer from sleep. "
  • 452 Answers
SOURCE: Dell D630: Took only the screen apart (did not
The sensor is next to the hinge on the left hand side. The lid closed state can also be configured in Windows.
Posted on Dec 23, 2010
  • 564 Answers
SOURCE: dell insprion laptop is still running after closing the lid
open control panel and go to power options. you should see "choose what to do when you shut the lid" click it and choose.
Posted on Nov 26, 2012
Notebook Crashes to PowerOff state when lid is closed
Running intense program with the lid closed will cause a sharp rise in temperature making the laptop hotter than it should be leading it into a shutdown. The second issue, windows should be shutdown properly rather than closing the lid, this makes the operational system unstable and will cause files to corrupt eventually.
May 23, 2012 | ASUS N82JQA1 14 HD Notebook Intel Core...
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
My computer windows station is sutting down repeatly and before shutdown show a massege, that is the application failed to intialize because the window station is shutting down
Shutting Down is powering off your computer, That message is just telling you that windows is turning off your computer and closing all programs. If an application fails to initialize it just means it can not start as windows is shutting down
Oct 07, 2010 | Computers & Internet
How do i shut down my dell inspiron just by closing it
Go to power settings, and change the what to do when I close my lid to either HIBERNATE or SHUTDOWN
http://www.ehow.com/how_4864887_change-happens-close-laptop-lid.html
May 20, 2010 | Computers & Internet
The computer hiberates when I close the lid, then I have to shutdown & restart to resume working. Can I avoid this somehow?
  1. right click your desktop and select properties
  2. select the screen saver tab
  3. at the bottom click the "power" option
  4. deselect the option for hibernation
  5. make sure your hdd is NOT set to turn off when the lid is closed
you can actually set the laptop up to continue running even programs when the lid is closed. this is the best option if you are constantly running application that require an extended wait period between startup and shut-down
good luck and pls rate this post
Mar 23, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
Close lid of laptop without shutting down system
You have to configure what laptop do when the lod is closed . go to Control Panel , Power Options , Advanced . In this tab you will see an option " When I close the lid " and a drop down menu just choose do nothing and press ok . It will not shut down your laptop when lid is closed .
If you like my solution do vote for me
Farhan
www.senseapplied.com
Jan 05, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Logging Off and won't come back on what to do
You can shut it down hard (by holding the power button until it shuts off), wait at least 10 seconds (for your hard drive to stop spinning) then start it up and then try shutting down windows normally instead of just closing the laptop's lid. You can then go into user accounts and delete all accept for your Administrative account (even Guest account), and see if that cures your ills.
Good Luck.
Feb 24, 2008 | Dell Inspiron 6400 Notebook
Dell Latitude E5410 Notebook Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
