Question about Logitech WingMan Formula GP Wheel And Pedals Set
15 pin (male point input) jack broken down. where can i purchase a new code wire?
2 Suggested Answers
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
i have 2.1 channel speaker set it was not working what is the solution
Posted on Mar 08, 2011
How do I reconnect the two small speakers to my system if they have been cut off from the actual speakers?
If you need to connect new male connectors to the wire ends you can get them from any good electrical shop! Some are solder-less connections or if you are handy with a soldering iron you can do a proper job on it!
Dec 31, 2014 | GPX Hm3817dtblk Home Music Hi-fi System -...
eBay and amazon have some pretty cheap ones. Fred mayers has some for $20 but they're really durable.
Dec 05, 2012 | Computers & Internet
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
My computer monitor say no input signal, what is the best sulotion
Make sure your monitor cable is connected/seated correctly and firmly on both; monitor and computer.
If that fails, you may have a bad graphics card. Now, if you have an extra monitor, you could always plug that one in to see if your graphics card is working. If that works, then your other monitor is bad.
This problem can also be caused by the RAM or CPU not seated properly in their sockets. Check to see if they are seated correctly.
Jun 20, 2011 | Computers & Internet
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
Hi Guy's I have an Acer Aspire 5315 laptop and a 32" Bush flatscreen TV. What cable do I need to connect the 2 to watch movies etc Cheers
Use a 15-pin, male-to-male VGA cable to connect your laptop to your TV. male-to-male means the pins are sticking out on both ends. Since both ends are male, you'll need to find the female VGA input on your laptop and on your TV. This is often called the PC input. Now, connect one end into the TV and one end into the PC. On a Mac, the VGA input is conveniently labeled with a "display" icon. It's recommended that you do this with everything powered off.
Sep 27, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Input wires broken loose, not sure where the go to
The center pin is your tip..which should have a wire going from 1/4" jack to the XLR jack. Pin 1 is earth ground...should be coming from 1/4" jack sleeve. Pin 3 would come from the 1/4" jack ring.
http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/XLR_pinouts.svg/540px-XLR_pinouts.svg.png
If you are still having trouble, post links to pictures of the internals of the guitar showing the assembly.
Mar 27, 2009 | Music
I was told I can hook up my computer monitor to my Sharp 40 inch
Your video adapter will only supply video input from your computer to your television. You must use an audio cable from the audio out of your computer (that would be the jack that you would normally plug your computer speakers into) to the audio input jack of your television shown below.
To do this, you will need a double male 1/8" stereo sable audio cable seen below.
One end plugs into your computer audio out and the other end into the audio jack shown in the illustration. You will then get your computer audio through your television speakers. You will be able to control the sound both with the television audio and the computer audio settings.
Mar 25, 2009 | Sharp LC37SH20U 37 in. LCD Television
My guitar hero world tour drum kit is broken
If you know how to solder, you can resolder the wire back onto the connector. I just did that tonight actually. the orange cymbal has a white wire and a black/bare copper wire. You can cut open the male connector [I use an exact-o knife along the underside mold line] (one side only) so you can just slide the wires/connector back into it. The white would solder onto the base of the male connector. The bare copper thats wrapped around the white one is the black/bare copper wire mentioned above. This one is soldered to the tip [the solder point inside that small black plastic piece] of the connector. Once you have it soldered, just slip the male connector rubber piece back into place and use some super glue to glue back together.I wrap it in electrical tape just so its definitely secured. If wire length is an issue, simply solder some wire extensions before soldering to the male connector/plug.
Mar 22, 2009 | Nintendo Activsion Guitar Hero® World Tour...
Logitech WingMan Formula GP Wheel And Pedals Set Logo
43 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
