Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Sony WEGA KDF-50E2000 - Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
    Top Expert:
  • Sony Master
  • 14,553 Answers
I see you posted the model number but some idea of what the set is doing or not doing is needed and if a image issue try to post a photo of it here.
Posted on Dec 05, 2012
  • 2 more comments
  • bidaling Dec 05, 2012
    the screen is cracked and i need to know hhow to replace it. i have another screen already. thanks
  • SD Tech
    SD Tech Dec 05, 2012
    Try to Google for a service manual for this manual but I can tell you the whole top screen unit will likely have to come off to get at the screen unit---not real easy and some real pitfalls---I did several and each was different, one had a piece of tape inside that could be seen in the picture---over 60 screws and numerous items to get at. A full service manual should have an exploded view and some instructions for this fix.
    difficult even if just the front protective plastic screen?
  • SD Tech
    If it is installed they way I think, you will with top apart have to remove inner screens first to get at it as it is blocked by them.
mistersony
  • 320 Answers
SOURCE: sony kdf-50E2000
bad lamp driver, if you have already replaced the lamp. If not, try replacing the lamp WITH AN ORIGINAL SONY LAMP!. Don't waste time with cheap replacements, you get what you pay for.
Posted on Oct 18, 2008
  • 87 Answers
SOURCE: sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
Posted on Apr 14, 2009
  • 476 Answers
SOURCE: have a sony kdf-50e2000 pic clear but green
dbrian07, most of these problems are caused by a defect in the optical block or light engine, your description of the problem points out to this particular area. there are some websites that can give you prices for either rebuilt or replacement light engines, you will need to type in your complete model number, and SONY USA.COM has a website i think they also can help you with parts for this model. please leave your feedback if i answered your question. thanks!
Posted on Aug 25, 2009
Testimonial: "THANK YOU WILL CHECK WEBSITE"
  • 160 Answers
SOURCE: How do I change my
Hello.
You have to get lamp fully assembled for easy replacement. That mean lamp should be purchased already installed in black plastic housing.
If you stand behind of your TV set on the left hand side (actual side) of your TV you will locate lamp door cover with latch on the top of it. Just push the latch down and remove cover. Deeper inside you will locate black plastic lamp door with handle that you have to rotate 1/8 of the turn counter-clockwise to open it up ( like a submarine style thing). Pull it out and next thing that you will discover - lamp assembly itself. Put your index finger inside of the ring-looking latch, pull it up and out. You have lamp removed now. Extremely carefully install new lamp in same order making sure that new lamp is ALL WAY IN (there is safety switch that sense if lamp is not properly in) and install the door making sure it is ALL WAY IN and LOCKED (there is another safety switch that sense it). If any of the switches will not sense proper installation TV WILL NOT turn on.
You can turn TV on to check if it is working. Last thing to do - reinstall lamp door cover.
Russ.
Posted on Dec 01, 2010
SD Tech
  • 14553 Answers
SOURCE: sony grand wega kdf-50e2000, red line on top of screen, after replacement of lamp.
Double check positioning of lamp if problem was never there before.
Posted on Sep 01, 2012
My 50" Sony Wega kdf50E2000
the lamp door cover is not secured properly or the lamp is not inserted correctly. Thats what the 3 blinks is indicating.
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
Sony Grand Wega KDF-50E2000 3 red blinks
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
Mar 28, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a Sony Wega KDF-50E2000 that doesn't turn on. The green light blinks for a minute or so and then the red "timed out" light blinks continuously. Yesterday, the TV turned itself off with the green...
Did you replaced lamp in TV recently?
I think TV needs new lamp as existing is either broken or dead.
Lamp replacement procedure would be mentioned in user manual or let me know to provide you more info.
Thanks.
Sep 16, 2009 | Sony KDF-50E2000 50" HDTV
Sony wega kdf-50e2000 standdby light blinks 8 times
Mar 25, 2009 | Sony KDF-50E2000 50" HDTV
Sony kdf 50e2000 fans not working now: read below...
hi, Why did you change the thermal fuse - specify the original problem, where the fans working before and need the correct model number before I can help you.
Model kdfe2000 is not listed anywhere.
Aug 26, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
