15 pin (male point input) jack broken down. where can i purchase a new code wire?
EBay and amazon have some pretty cheap ones. Fred mayers has some for $20 but they're really durable.
Posted on Dec 05, 2012
5 Suggested Answers
  • 502 Answers
SOURCE: DC input jack broken
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Posted on Mar 14, 2009
TechieJon
  • 43 Answers
SOURCE: One of the 3 Male Jack Prongs is broken off.
This will likely require some soldering, if you are referring to the jack on the dc converter (black box) you should exercise care when opening these there coiuld be hazardous electricity in it even if unplugged. (if it can be opened, many are permanantly glued shut) you can order replacements on ebay relatively cheap, usually $15-30.
Posted on Jul 20, 2009
poole72
  • 71 Answers
SOURCE: DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Posted on Dec 02, 2009
kamacosmic
  • 135 Answers
SOURCE: how to remove broken headphone
you can use a tweezer if a piece is sticking out. If not you will have to apply strong super glue to another thin metal piece (perhaps a needle) then attach it to the end of the broken-off earphone jack piece. Hold it for at least 3-5 minutes then pull.
good luck
kc
Posted on Feb 23, 2011
How do I reconnect the two small speakers to my system if they have been cut off from the actual speakers?
If you need to connect new male connectors to the wire ends you can get them from any good electrical shop! Some are solder-less connections or if you are handy with a soldering iron you can do a proper job on it!
Dec 31, 2014 | GPX Hm3817dtblk Home Music Hi-fi System -...
Connect to TV
If your laptop has the 15 pin vga socket on the side or the back and your tv has a 15 pin socket on the back then you just need a 15 male to male vga lead to connect the two together. Then select PC on you tv menu using the tv remote as the input source and switch the laptop on. Ebay has the lead you need.
May 05, 2012 | HEWLETT-PACKARD Elitebook 8460P
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
My computer monitor say no input signal, what is the best sulotion
Make sure your monitor cable is connected/seated correctly and firmly on both; monitor and computer.
If that fails, you may have a bad graphics card. Now, if you have an extra monitor, you could always plug that one in to see if your graphics card is working. If that works, then your other monitor is bad.
This problem can also be caused by the RAM or CPU not seated properly in their sockets. Check to see if they are seated correctly.
Jun 20, 2011 | Computers & Internet
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
Hi Guy's I have an Acer Aspire 5315 laptop and a 32" Bush flatscreen TV. What cable do I need to connect the 2 to watch movies etc Cheers
Use a 15-pin, male-to-male VGA cable to connect your laptop to your TV. male-to-male means the pins are sticking out on both ends. Since both ends are male, you'll need to find the female VGA input on your laptop and on your TV. This is often called the PC input. Now, connect one end into the TV and one end into the PC. On a Mac, the VGA input is conveniently labeled with a "display" icon. It's recommended that you do this with everything powered off.
Sep 27, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Input wires broken loose, not sure where the go to
The center pin is your tip..which should have a wire going from 1/4" jack to the XLR jack. Pin 1 is earth ground...should be coming from 1/4" jack sleeve. Pin 3 would come from the 1/4" jack ring.
http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/XLR_pinouts.svg/540px-XLR_pinouts.svg.png
If you are still having trouble, post links to pictures of the internals of the guitar showing the assembly.
Mar 27, 2009 | Music
I was told I can hook up my computer monitor to my Sharp 40 inch
Your video adapter will only supply video input from your computer to your television. You must use an audio cable from the audio out of your computer (that would be the jack that you would normally plug your computer speakers into) to the audio input jack of your television shown below.
To do this, you will need a double male 1/8" stereo sable audio cable seen below.
One end plugs into your computer audio out and the other end into the audio jack shown in the illustration. You will then get your computer audio through your television speakers. You will be able to control the sound both with the television audio and the computer audio settings.
Mar 25, 2009 | Sharp LC37SH20U 37 in. LCD Television
My guitar hero world tour drum kit is broken
If you know how to solder, you can resolder the wire back onto the connector. I just did that tonight actually. the orange cymbal has a white wire and a black/bare copper wire. You can cut open the male connector [I use an exact-o knife along the underside mold line] (one side only) so you can just slide the wires/connector back into it. The white would solder onto the base of the male connector. The bare copper thats wrapped around the white one is the black/bare copper wire mentioned above. This one is soldered to the tip [the solder point inside that small black plastic piece] of the connector. Once you have it soldered, just slip the male connector rubber piece back into place and use some super glue to glue back together.I wrap it in electrical tape just so its definitely secured. If wire length is an issue, simply solder some wire extensions before soldering to the male connector/plug.
Mar 22, 2009 | Nintendo Activsion Guitar Hero® World Tour...
Computers & Internet Logo
David Payne
David Payne
