Question about SNK Televison & Video
Magnavox 42" plasma no picture or sound when hooking up ps3 to hdmi
Installed used television from family friend, I plugged the television in, plugged the monster cable hdmi into the tv and the ps3 and it shows a blank screen. i have tried multiple cables jiggling connections, both hdmi sockets on the television. the ps3 and cable works fine on my older visio lcd. i need help ! ive spoent quite a bit of time trying to figure this out
  • Nathaniel Ryan Dec 05, 2012
    Theres no sound and no picture at all. i could see that being the solution if the picture was faint. but thankyou.
  • Anonymous Mar 31, 2014
    Blank picture have done another auto channel search same result. Used different tv to verify cable is ok. Tv works fine with dvd
  • 1,238 Answers
Try to adjust your resolution to the highest level, ps3 is a very high grapics device..
thanks.
Posted on Dec 05, 2012
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
  • 4234 Answers
SOURCE: Samsung 42" Plasma HDTV cable hookup problem
There sould not have been sparks. Check the following: Using a voltmeter check between the cable itself and ground. There should not be any reading (anything less than .1V is normal). Check again between the inner hole of the RF connector and the outside part. Again there should be less than .1V. If you read any voltage at the RF connector, the TV is faulty and should be exchanged. If you read voltage at the cable, have teh cable company check again.
Dan
Posted on Jul 30, 2008
  • 458 Answers
SOURCE: cant get 42''lcd telly to let me play ps3 threw hdmi cable
You will most likely have to contact your LG dealer to fix this. The problem is due to the HDMI input not recognising the playstation, the cure for this is a software upgrade for External Device IDentification (EDID), which can only be done by a service centre.
Posted on Mar 29, 2009
  • 105 Answers
SOURCE: Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Posted on Apr 29, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-46PZ85U Plasma TV
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Posted on Jan 27, 2010
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
4. perform setup.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
No pic no sound, power on
NO PICTURE NO SOUND THAN CHECK THE SESTOM CONTROL IC IT IS FAULTY
Mar 29, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Just bought a 50 panasonic viera, when we hook up ps3 on hdmi cable, we have sound but no picture.
Plasma TV normally do not have the resolution required for PS3 unless the plasma TV is fullHD( 1920x1080p) pixels.
HD Ready Plasma = 1024 x 768p
PS3 Outputs = (fullHD)1920x1080 or (HDReady) 1280 x 720p.
LCD TV accepts the resolution matches the resolution the PS3 is outputting.
Feb 28, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
HDMI input
do you have audio out on the tv? if so then yes it will but if you dont then it wont
Dec 21, 2008 | Sanyo DP42746 42 in. Plasma Television
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Mar 12, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Open Questions:
Televison & Video Logo
173 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
