Samsung ws 32z308p
Vertical unstable picture that ends with the TV off
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I have seen the reviews of this set in the UK and they are not very good as far a quality of picture etc. I would suspect the first place strangely enough would be the power supply which is about the 1st thing in most cases to look at.
If you are not able to do that have it looked at by a shop before it gets worse and or damages parts that are currently good.
If you smell leaking petrol from your car that is the time to have it looked at, same with this.
Posted on Dec 05, 2012
2 Suggested Answers
  • 927 Answers
SOURCE: Hitachi 50UX10B rear projection TV
Good Day, eledttech;
Symptom: NO SYNC ON MAIN PICTURE PIP OK
Cause: IX04.
Good Luck, big IRISH.
Posted on Aug 19, 2008
TV Samsung WS-32Z308P (Slim-Fit CRT). Chassi S62A. TV keeps turning on and off in a 15 min cycle.
mine had 6 bad capasitors on which i replaced for 3.99 and been fine since.heres where i got my guide from.hope it helps...
ELECTRONIC EQUIPMENT REPAIR CENTRE
samsung smart tv fix YouTube
Dec 03, 2013 | Samsung WS32Z308P 32" TV
Samsung dynaflat 1080i owners manual
Check the links below for help;
www.tv.manualsonline.com/???manuals/mfg/???samsung/???samsung_txr2035_???txr2035xxaa.html
www.devicemanuals.com/guide/Television/???Samsung/???Samsung-WS-32Z308P-DynaFlat-hdtv-users
Sep 25, 2010 | Televison & Video
Pc to tv connection keeps scrolling vertically
its probably your caps on the signal module
c2p05 and c2p08 100uf 16v capacitors
did the problem used to only happen when it was cold? = caps
is there rolling bars? is it a dark unstable picture? = caps
let me know if you need further assistance, the caps solder in
Jun 18, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Apr 03, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
